As the title, on my monitored server, the number of start agentd always is 6, how could I control it?
How to set the number of start agentd
Hi Davidus,
Thanks for you reply, but as I've said, it doesn't work for me, no matter what number I set, the number of running agent is always 6.Comment
This is a few months old but I was just researching this myself, so I thought I'd offer a (hopefully correct) answer.
The "StartAgents" parameter is specifically about the number of processes that start and listen for passive requests, but there are additional processes started for other purposes. You can see them being started in the zabbix agent log file when it starts up:
In my case I have StartAgents set to 2, and I have active checks enabled. So I get 2 listener processes and 1 process for handling active checks and the collector process that collects data.Code:2470:20121203:145031.522 agent #0 started [collector] 2471:20121203:145031.522 agent #1 started[listener] 2472:20121203:145031.522 agent #2 started[listener] 2473:20121203:145031.522 agent #3 started [active checks]
Now if I set StartAgents=0 and restart the zabbix agent:
If I uncomment StartAgents completely, I get 5 processes because the default is three listeners:Code:5440:20121203:145920.272 agent #0 started [collector] 5441:20121203:145920.272 agent #1 started [active checks]
So at the very least, if you're trying to figure out why the zabbix agent always starts six processes, check the startup messages in the agent log and see what those processes are being started for.Code:5638:20121203:150046.743 agent #0 started [collector] 5639:20121203:150046.743 agent #1 started[listener] 5640:20121203:150046.743 agent #2 started[listener] 5641:20121203:150046.743 agent #3 started[listener] 5642:20121203:150046.743 agent #4 started [active checks]
