I have problem with using ( and installing ) zabbix_agentd 2.0 on win2k SP4. When I try to run zabbix_agentd.exe I get popup window with message: "The procedure entry point DnsFree could not be located in the dynamic link library DNSAPI.dll."
I found this information ( however I'm not sure if it has anything to do with my problem ):
http://msdn.microsoft.com/en-us/libr...(v=vs.85).aspx describing DnsFree function says:
Minimum supported client Windows XP
Minimum supported server Windows Server 2003
Does this mean that zabbix_agentd won't work on Windows Server below 2k3? Zabbix documentation says that version 2.0 needs win2k and above...
br,
Kamil
br,
Kamil
