Zabbix update is too long
  • FreeD
    • Aug 2011
    • 68
    Hello.
    I think it's not normal:
    | 11524 | root | localhost | zabbix | Query | 103068 | Sending data | INSERT INTO tmp_events_eventid (eventid,prev_value)
    Database: ~65,900,996 rows, InnoDB , 6.1 GB
    MySQL used 2.2 GB RAM ( innodb_buffer_pool_size = 2G ) and 100% of one core (one core as i understand because only one request is running).
    table "events" ~1,895,409 rows and 290.6 MB
  • jerry
    • Jan 2009
    Same here.
    Right now it's running for more than 6 hours (first tmp_events_eventid query).
    We have more than 41 million rows in table events and it takes more than 2.5GB on disk size.
    Does anybody know if I can skip these steps from upgrade procedure?
    I think script is only trying to decide which events made changes and which not.
    I do not know if this is used somewhere and if it creates problems afterwards or not.
    Can somebody explain what should we do?
    • FreeD
      • Aug 2011
      • 68
      I think something wrong in patch
      | 17526 | root | localhost | zabbix_2 | Query | 452 | Sending data | INSERT INTO tmp_events_eventid (eventid,prev_value)
      mysql> select count(*) from zabbix_2.tmp_events_eventid;
      ERROR 1146 (42S02): Table 'zabbix_2.tmp_events_eventid' doesn't exist
      • jerry
        • Jan 2009
        That's OK, cause it's temporary table.
        I am right now searching code, where is events.value_changed used. I am trying to decide if it will make problem importing historical data without this flag properly set.
        • jerry
          • Jan 2009
          From my point of view, these steps could be skipped. You just don't get additional info for old events - info which was not present until 2.0.0 (not counting dev channel (1.9.x) - how many changing events was there.
          I am going to give it another 12 hours or so. If it won't make in that time, I will skip this part of migration.
          I was searching code and I don't found anything which could create problems in the future. Hopefully I am right.
