graph.get wrong graphid
  • marsipulami
    • May 2012
    • 18
    I have a lot of hosts in zabbix. all of these hosts share the same template and graphs.
    When i use the api function graph.get i expect the actual graphid of the specific host instead of the graphid of the template. I get the "templatepgraphid" for every host.
    What is wrong with my code? thanx in advance
    						   "jsonrpc":"2.0",
    						   "method":"graph.get",
    						   "params":{
    							  "output":"extend",
    							"filter":{
    								 "hostids":[{
    									"hostid":"'.$array[$i].'"
    								 "templateids":
    										[{"templateid":"100100000000402"}]
    							  "limit":1
    						   "auth":"'.$auth.'",
    						   "id":2
  • mmarkwitzz
    • Jan 2011
    • 106
    Hostids and Templateids should be directly in params (not in filters) and the type should be array (not hash list), like below. I tested it with hostids with my own scripts and works as expected. Dunno about templateids, but it should follow the same rules.
    				   "jsonrpc":"2.0",
    				   "params":{
    					  "output":"extend",
    					  "hostids":[	"'.$array[$i].'" ],
    					  "templateids":[ "100100000000402" ]
    					  "limit":1
    				   "auth":"'.$auth.'",
    				   "id":2
    Now, if I only knew how to specify the parent hostid for graph.create...
