zabbix2.0 deploy failed with offical documents
  • complexray
    • Jun 2012
    Hi, All
    I encountered some problem when I deploy zabbix 2.0 with offical documents.
    Please help to check and analysis.
    #cd /usr/local/src
    #wget http://downloads.sourceforge.net/pro...dnetworks-kr-2
    #tar -zxvf zabbix-2.0.0.tar.gz
    #groupadd zabbix
    #useradd -g zabbix zabbix
    #mysql -uroot -p123456
    mysql>create database zabbixdb;
    mysql>insert into mysql.user(Host,User,Password) values('localhost','zabbixuser',password('123456') );
    mysql>grant all on zabbixdb.* to 'zabbixuser'@'%' identified by '123456' with grant option;
    mysql>flush privileges;
    mysql>source /usr/local/src/zabbix-2.0.0/database/mysql/schema.sql
    mysql>source /usr/local/src/zabbix-2.0.0/database/mysql/data.sql
    mysql>source /usr/local/src/zabbix-2.0.0/database/mysql/images.sql
    mysql>exit;
    #mkdir /usr/local/nginx/html/zabbix
    #cp -R /usr/local/src/zabbix-2.0.0/frontends/php/* /usr/local/nginx/html/zabbix/
    #chown www. -R /usr/local/nginx/html/zabbix
    #chmod 700 -R /usr/local/nginx/html/zabbix
    #vi /etc/php.ini
    memory_limit = 256M
    post_max_size = 32M
    max_execution_time = 600
    #cd /usr/local/src/zabbix-2.0.0
    #./configure --enable-server --enable-agent --with-mysql --enable-ipv6 --with-net-snmp --with-libcurl
    #make install
    #vi /usr/local/etc/zabbix_server.conf
    DBName=zabbixdb
    DBUser=zabbixuser
    DBPassword=123456
    #cp /usr/local/src/zabbix-2.0.0/misc/init.d/red hat/zabbix_agentd_ctl /etc/init.d/
    #cp /usr/local/src/zabbix-2.0.0/misc/init.d/red hat/zabbix_server_ctl /etc/init.d/
    #cd /usr/local/sbin/
    #zabbix_server -c /usr/local/etc/zabbix_server.conf
    #cd /etc/init.d/
    #./zabbix_server_ctl start
    END
    when I open the http://132.160.160.31/zabbix/ (this's my local machine), I found the zabbix server no running.
    I can use the commond "mysql -uzabbixuser -p123456" login the mysql successfully.
    The iptables has permit 10050/10051 tcp/udp ports.
    By the way, the server is running cacti normal.
    What should I check when I do these operations.
  • Jason
    • Nov 2007
    • 431
    First thing I'd do is to check the server log and see what it stopped... look in /tmp
    • aharvey
      • Oct 2011
      Are you trying to use nginx instead of the required/recommended apache/httpd?
      • osits
        • Jul 2012
        Zabbix 2.0.1 installation help
        Hi Jason, can you please advise me how to install ZAbbix 2.0.1 on ubuntu 12.04 server. MySQL, Apache and PHP is already installed on the server.
        Suren
