Zabbix 1.8.11 to 2.0 problem in windows service restart
  • alderaan
    • Aug 2011
    • 14
    Hi with zabbix 1.8.11 in action i can restart a windows service with
    {HOSTNAME}: sc stop windows_service
    {HOSTNAME}: sc start windows_service
    but now with 2.0 it doesn't work. Has anyone idea of what is different? How can i restart a windows service.
    I do a check with item:
    service_state[service] and trigger:
    {server:service_state[service].last(0)}#0
    Alderaan
  • alderaan
    • Aug 2011
    • 14
    Alderaan
    No ideas about this problem?
    • richlv
      • Oct 2005
      • 3112
      syntax for remote commands has changed - you don't specify host in the command itself anymore, you just select them and the command is just that - w/o host specification prefix
      • alderaan
        • Aug 2011
        • 14
        Hi, same problem. Followind my conf:
        Commands:
        sc stop FortiExplorerDaemon
        sc start FortiExplorerDaemon
        • alderaan
          • Aug 2011
          • 14
          Solved
          [QUOTE=alderaan;103114]Hi, same problem. Followind my conf:
          Commands:
          Problem solved. Need to specify full path:
          c:\windows\system32\sc.exe stop service
          c:\windows\system32\sc.exe start service
