UserParameter problem on Zabbix_agentd 2.0
  • Buzz
    • Aug 2007
    • 17
    I just upgraded Zabbix from 1.8.8 to 2.0.0.
    The server works fine, except that it sets as "unsupported" all the items linked to a userparameter.
    I created a test userparameter, that calls a script which only echoes a number (57).
    When I run zabbix_agentd -p, it display "test [t|57]"
    So it succeeds to execute my script... But on the server side, it says that the test item isn't supported..
    And I have this same behaviour with each userparameter..
    Any clue would be highly appreciated !
    Regards,
    Buzz.
  • piet
    • Jun 2012
    same for me
    UserParameter=abc,shellscript(x)
    example: UserParameter=test_1,ping -c3 192.168.1.1
    if i do zabbix_get abc it doesnt work (item unsupported), if i do zabbix_get shellscript(x) it works
    • Buzz
      • Aug 2007
      • 17
      indeed !
      Yes Piet, you're right !
      In my agent config file, I have
      UserParameter=cpu.iowait,/home/zabbix/bin/cpu.iowait.bsh
      In the Zabbix GUI, I configured the item with :
      type = External check
      key = cpu.iowait.bsh[]
      and it works this way...
      Could somebody from the Zabbix team confirm that it's the normal way of doing it... or if it is a little bug... before I start upgrading the agent on all my clients ?
      • richlv
        • Oct 2005
        • 3112
        i don't believe it works as you expect it to work... external checks are executed by the server. if you actually want to use userparams, type must be agent or agent (active)
        • Buzz
          • Aug 2007
          • 17
          Oups ! OK !
          But when I turn it to "Agent" or "Agent (active)", it switches to "Unsupported".
          What am I missing ? is there some option to activate in the agent or server's config files ?
          Looks really weird, because when I run zabbix_agentd -p, it shows the item as supported...
          • Gunsthall
            • Jul 2011
            • 15
            Permissions?
            It may sounds stupid but ... are you sure execution permissions were not changed when you upgraded? Take a look, just in case.
            • Buzz
              • Aug 2007
              • 17
              Hi Gunsthall,
              I double-checked the permissions on the script that's called by my item, but it's OK : the zabbix user can read and execute it..
              I even changed my agent's configuration file so that it runs as root. And even so, the problem remains.
              So I don't think it's a permission problem.
              I created a new agentd configuration file from the templates delivered with Zabbix 2.0. But it doesn't solve the issue...
              When I run zabbix_agentd -p , it shows my item as supported, but when I launch the agent with debuglevel=4, the agent's log says :
              2163:20120620:090753.418 Processing request.
              2163:20120620:090753.418 Requested [cpu.iowait[]]
              2163:20120620:090753.418 Sending back [ZBX_NOTSUPPORTED]
              and if I test my item with zabbix_get, I get the correct value for the item...
              I'm running out of ideas...
              • piet
                • Jun 2012
                Maybe i have requested the wrong way. The server requests the data - thats obvious. How do i get the data.last(0) from the database. If i use the ping in a map to describe a connection with "live"-data i want to get from the database not from the client itself.
                In zabbix 1.8.x i used something like server.userparameter.last(0) to get this and this seems not to work in 2.0
                • jessi
                  • Apr 2010
                  hi all.
                  not sure what the issue is but im having the same problem with 2.0..
                  no UserParameter i try is working for me..
                  i have:
                  UserParameter=test,cat test.txt
                  which is simply a file with a 0 in it..
                  but nothing i try seames to get this to work.
                  zabbix_get always returns ZBX_NOTSUPPORTED
                  permissions are fine and what im trying to do is just confirm a simple test works...
                  • richlv
                    • Oct 2005
                    • 3112
                    you assume test.txt is in the current directory, which is not the case. try something like:
                    UserParameter=test,echo 13
                    UserParameter=test,cat /full/path/to/test.txt
                    • jessi
                      • Apr 2010
                      Sorry i should have been clearer..
                      i am doing that..
                      UserParameter=test,cat /opt/zabbix/test
                      i have a script that echo's a 0 to this file if certain conditions are met.
                      permissions are as so..
                      -rwxrwxrwx 1 zabbix zabbix 2 Aug 14 12:39 test
                      from what i see it would appear that nothing i add to the agentd.conf is being interpreted.. "this should have been my first clue"
                      so i have just now created a new one and recompiled zabbix 2.0 from scratch.."server and agent"
                      i seam to remember that during compile time i had to stipulate the conf path..
                      and i think thats were it has gone wrong..
                      by default its in /usr/local/etc/
                      changing it there seams to have fixed the issue..
                      although i did stipulate the confs location...
                      [root@zabbix zabbix]# zabbix_get -s localhost -k test
                      0
                      so rtfm saves the day...
                      im not to proud to mention this has taken me 4 hours...
                      now to setup the items and triggers.
                      thanks for the assist..
                      • Buzz
                        • Aug 2007
                        • 17
                        sorry to come back with this, but for me it just does not work..
                        All my userparameters became unsupported when I upgraded to 2.0.
                        Here are the tests I did :
                        I have the agent's config file in the default location : /usr/local/etc
                        I contains the following userparameter :
                        UserParameter=test,echo 57
                        - I'm sure the agent uses this configuration file, because when I rename it, the agent refuses to start.
                        - when I run
                        zabbix_agentd -p | grep -i test
                        I get
                        test [t|57]
                        - when I run
                        I don't get any result. But if I replace localhost with the IP of the machine, I do get 57
                        so the agent seems to be able to run my test.
                        But when I try to monitor this item on server, I always get the following line in the server log :
                        item [Kermit:test[]] became not supported: ZBX_NOTSUPPORTED
                        And if a downgrade the agent to 1.8, the problem disappear.
                        On the server side, the item is defined as follow :
                        type = I tried Zabbix agent (active), Zabbix agent, External check
                        type of information = numeric unsigned
                        I also checked that the agent and server were both in version 2.0.
                        I'm pretty sure I did something obviously stupid somewhere.. but I just can't find it out...
                        Thanks in advance for any idea !
                        • mbsit
                          • Sep 2012
                          • 130
                          Are you sure that:
                          -k test
                          is the same as:
                          Key test[]
                          If you don't want to use parameters in scripts, do not use bracket in Key of item.
                          Bests,
                          Grzegorz
                          Pozdrawiam
                          Grzegorz Grabowski
                          ____
                          WdroĊĵenia, szkolenia, umowy serwisowe
                          Warszawa - Polska
                          • piet
                            • Jun 2012
                            v2.0.0 vs v.2.0.2
                            Buzz,
                            Have you upgraded ? That solves the problem for me.
                            rgrds
                            • Buzz
                              • Aug 2007
                              • 17
                              #15
                              Hi Mbsit, Piet
                              thanks for your answers.
                              Mbsit : indeed I'm not sure test[] is the same as -k test...
                              I tried to replace test[] by test , but it doesn't solve the issue.
                              Piet, thanks for the suggestion. I'm gonna upgrade... but not today, since I'm on holiday starting tonight..
                              I'll upgrade this thread as soon as I complete the upgrade.
                              Kind regards,
                              Buzz
