Configuration of screens
  • piet200
    • Jan 2012
    • 12
    I use some zabbix items of the type log to get logging information out of some files and present this information in a screen.
    When I add a resource to the screen of the type "Plain text" I can enter the number of lines of information which will be visible,
    When I choose for example 10 lines, I am not able to see older information then only shown in the last 10 lines
    Is there a way to scroll through all the lines and not only the last 10 or 25 lines ?
    Is there any other way to show all information ?
  • piet200
    • Jan 2012
    • 12
    no solution for something that seems so easy to do ?
    • paulmeyer
      • Jun 2012
      just saying good luck for the right answer
      we all know that there's a solution for that and leave it to the expert for the right answers..,,
