Zabbix poller processes more than 75% busy
  • fanf074
    • Jul 2012
    Hi all,
    I configure ZABBIX to monitor 40 Hosts (Windows servers) and i have this alert in my dashboard : Zabbix poller processes more than 75% busy
    Does anyone have a solution for this problem ?
    ZABBIX run with the ZABBIX 2.0 VIRTUAL APPLIANCE (VMWARE).
    Thanks for your answers.
  • jix
    • Feb 2011
    • 73
    Try to increase your start poller in zabbix server configuration
    • fanf074
      • Jul 2012
      Hi all,
      Even if i put the zabbix start pollers @ the max (1000), i have always the poller busy @ 100% ! It's change nothing for me.
      Ave you another idea ?
      • cheezus
        • Nov 2011
        • 35
        You can forget trying to get help on these forums. Zabbix is cool but performance is awful and building a server from scratch with it is hard as heck. We've never been able to to do it 100% correctly with all things like snmp traps, etc., working.
        Posting on here is like pissing in the wind. They want you to buy their support plans so don't answer. Wish I could help but I'm in the same boat which lead me here. Unfortunately we're going to have to ditch zabbix because it's it's performance is severely lacking.
        Don't get me wrong, we used to love zabbix. But these forums are nothing but dead end threads of issue, after issue. The support plans have become outrageously priced like zenoss did. It's sad, really, as we were once vocal supporters of zabbix
        • jix
          • Feb 2011
          • 73
          im agree with cheezus
          but the way
          tell me about your server status
          number of item?, active triger? , NVPS?
          • fanf074
            • Jul 2012
            Hi I'am a french Guy,So the dashboard will be in french.
            Here is the Dashboard :
            Serveur Zabbix en fonction Oui localhost:10051
            Nombre d'hôtes (surveillés/non surveillés/modèles) 65 41 / 0 / 24
            Nombre d'éléments (surveillés/non surveillés/non supportés) 2587 2405 / 0 / 182
            Nombre de déclencheurs (activé/désactivé)[problème/inconnu/ok] 1234 1232 / 2 [2 / 0 / 1230]
            Nombre d'utilisateurs 3 1
            Performance serveur requise, nouvelles valeurs par seconde 39.2 -
            Have you any idea ?
            • jix
              • Feb 2011
              • 73
              change your start poller to 50, and check your poller status...
              • ahowell
                • Jan 2011
                • 66
                I'm not sure what the performance problems your talking about are. We doing 680 vps with no issue what so ever on VMs with small amounts of memory and CPU, and yes with have SNMP traps working.
                I've found the support from the community on the forums to be quite good, and the official guys to respond quite quickly even without a support contract if you open a bug with sufficient detail.
                • bga83
                  • Sep 2011
                  • 268
                  Is there anything interesting in logs? It sometimes useful to increase Timeout parameter in zabbix_server.conf
                  • fanf074
                    • Jul 2012
                    I have always this problem . I will try to increase the timeout in the zabbix server.conf.
                    • jhrasko
                      • Aug 2012
                      maximum db connection reached
                      If you are using MySQL database try to increase max_connections parameter. When you start many pollers they create many DB connections and standard MySQL limit is 150. For example set it to 500.
                      • cheezus
                        • Nov 2011
                        • 35
                        BTW - We upgraded to 2.0 and changed all the agents to push instead of the server to poll and it's working solid so far.
                        • nicolasg
                          • Apr 2011
                          • 50
                          increasing the number of Zabbix pollers from 5 to 100 seems that solved the issue in my case.
                          • BDiE8VNy
                            • Apr 2010
                            • 680
                            [...]i have this alert in my dashboard : Zabbix poller processes more than 75% busy[...]
                            Just got that Trigger fired too after upgrading from 2.0.2 to 2.0.3 via RPM.
                            I used to source a file (/etc/sysconfig/zabbix) within the zabbix-server init script which sets some http_proxy variables. The init script has been replaced by the update and my web service checks run against the (fire)wall.
                            Adding the missing source command solved that issue (at least in my case).
                            • marmeks
                              • Dec 2012
                              I increased:
                              Zabbix_server.conf -> StartPoller from 5 to 50.
                              MySQL conf Max_connections from 200 to 400.
                              Restarted MySQL and Zabbix service.
                              Trigger on "Poller busy 75%" is gone.
                              So are gone many false positives on unreachable hosts.
                              And Zabbix queue (Administration -> Queue) looks much more better.
                              Thanks for advices!
