I have problem with setting action in Zabbix 2.0 using trigger created via new low-level discovery feature.
I configured some actions with "static" triggers and they are running well.
Now, we configured Template to monitor SAN switches via SNMP. To make it quicker we used low-level discovery feature and we created new rule for discovering ports. Then we created Item prototype for monitoring each discovered port status and Trigger prototype.
Ports are discovered. Data is collected. Triggers are also OK ( I see in Monitoring/Events that they properly switch to PROBLEM/OK state ).
However, actions are not working. When I configure Action and its conditions, I see nothing in Condition/Trigger Select window. I see "static" triggers, but not these configured as trigger prototypes. I also tried to use "Trigger Name like" instead of "Trigger" condition, but this also didn't work.
Did anyone configured action based on low-level discovery trigger? How to do it?
br,
kunajn
br,
kunajn
