I can not import XML templates into my Zabbix server.
Debian Squeeze
Source: zabbix (1:1.8.11-1)
Version: 1:1.8.11-1+b1
I believe I have the correct XML packages installed:
libxml2 install
php-xml-dtd install
php-xml-htmlsax3 install
php-xml-parser install
php-xml-rpc install
php-xml-rpc2 install
php-xml-rss install
php-xml-serializer install
xml-core install
This is from php.ini:
dom
DOM/XML enabled
DOM/XML API Version 20031129
libxml Version 2.7.8
HTML Support enabled
XPath Support enabled
XPointer Support enabled
Schema Support enabled
RelaxNG Support enabled
libxml
libXML support active
libXML Compiled Version 2.7.8
libXML Loaded Version 20708
libXML streams enabled
Am I missing something? When I import an xml template the banner turns green and says "Imported successfully" but I when on "all templates" I still only have 42 templates not 43 as expected.
Debian Squeeze
libxml2 install
php-xml-dtd install
php-xml-rpc install
php-xml-rss install
xml-core install
dom
DOM/XML enabled
libxml
