Image and background import
  • paszczak000
    • May 2011
    • 10
    I'm trying to import images and background from one Zabbix to another one.
    When I'm insterting records into DB, everything is fine. Example:
    INSERT INTO `images` VALUES(31, 1, 'e_cloud_off', 0x89504e470d0a1a0a0000000d...........
    In Zabbix GUI I can see images, but when I want to add another one using GUI I'm getting error:
    Duplicate entry '31' for key 'PRIMARY
    Why Zabbix GUI is trying to insert image at the same imageid?
  • paszczak000
    • May 2011
    • 10
    Solution: https://support.zabbix.com/browse/ZB...s:all-tabpanel
    You need to upgrade imageid in ids table.
