We are investigating various ways of gathering and reporting on metrics from a pool of about 50 monitored hosts. Many of those hosts run a Java based learning management system. All the hosts are virtual machines. We chose Zabbix to evaluate because of the Java Gateway feature.
We installed Zabbix server and the Java Gateway on a single VM with 4 CPUs and 6 Gb of memory. The OS is Red Hat Enterprise 6. The EVC mode is that of a Intel Xeon Core 2 processor.
We initially used the generic Linux template to gather metrics from all of our monitored hosts. We then fired up the Java Gateway and collected metrics from only ONE monitored host using the generic JMX and Tomcat templates.
Our problem is that with the Java Gateway running, the Zabbix web interface is very sluggish. The "top" command reveals that the Java Gateway is running at about 55% CPU utilization even without gathering any metrics.
We are considering moving the Java Gateway to another VM or to increase the horsepower of our Zabbix server VM.
Has anyone else experienced similar performance issues when using the Java Gateway? If so, what steps were taken to correct them?
Thanks in advance,
Trevor
Thanks in advance,
Trevor
