hi guys... i have the Zabbix 1.8.13 installed here and i'm trying to monitor the network traffic of some cisco routers...
it seems to be working when i test with the snmpget but the graphic makes only some points and not lines... see:
Monitoring --> Latest Data. Select the host and item you want, out to the right is a link for "Graph". Click on that. Top right is a dropdown that shows "Graph". Click the dropdown and pick what you want.
i had strange graphs like this using template "SNMP Interfaces". the problem was the interval, i changed it from 5 to 600. changing back to 5 solved my problem.
