Compiling 2.0.1 agent from source under linux
  • jeefoo
    • Jul 2012
    Hi all,
    Used OS's: fedora 17 64bit, centos 6.2 64 and i686.
    I would like to compile zabbix agent from zabbix-2.0.1 source.
    If I run ./configure --enable-agent the things goes well, and it end with a successful compilation.
    I need to build with static libraries, so if I run
    ./configure --enable-agent --enable-static I get the following error:
    checking for file /proc/net/dev... yes
    checking for long long format... no
    checking for -rdynamic linking option... yes
    checking for ICONV support... configure: error: Unable to find iconv.h "no"
    Even I try to compile as a user or root the result is the same.
    The missing iconv.h file is exist in /usr/include
    I tried to set LIBRARY_PATH and LD_LIBRARY_PATH to /usr/include, but it not helped.
    What did I wrong? - Thanks for your reply:
    Balazs Huvely
  • 0siris
    • Nov 2010
    • 76
    and if you run this before compiling:
    export path=/usr/include:$PATH
    • dakol
      • Jan 2008
      • 50
      Originally posted by jeefoo
      Hi all,
      look at the file config.log which should contains the failed test
      • rohit
        • Apr 2011
        Was not sure why modifying $PATH would help....but I gave it a try:
        [root@box1 zabbix-2.0.1]# find /usr/include/ -name iconv.h
        /usr/include/iconv.h
        [zabbix@box1 zabbix-2.0.1]$ echo $PATH
        /usr/lib64/qt-3.3/bin:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin:/home/zabbix/bin:/usr/include
        It failed with same error. Config.log says
        conftest.c:11:28: error: ac_nonexistent.h: No such file or directory
        Compiling agent without --enable-static works well
        I'm using RHEL 6.3 (2.6.32-279.el6.x86_64)
        -Rohit Kalsarpe
        • dakol
          • Jan 2008
          • 50
          do you have libiconv-devel installed ? (or something close)
          • rohit
            • Apr 2011
            nope...i dont have libiconv-devel installed
            • dakol
              • Jan 2008
              • 50
              on Redhat 5 update 5:
              $ rpm -qf /usr/include/iconv.h
              glibc-headers-2.5-76
              try install it
              • rohit
                • Apr 2011
                I already have it.
                [root@box1 ~]# rpm -qf /usr/include/iconv.h
                glibc-headers-2.12-1.80.el6.x86_64
                [root@box1 ~]#
                • Perec
                  • May 2012
                  Have you try to install "glibc-static" ?
                  • vudoo
                    • Aug 2012
                    Installing "glibc-static" with #yum install glibc-static seems to have fixed it for me, thank you.
