Send e-mail script does not work...
  • lberaldi
    • Jul 2012
    Hi, i'm having problem with sending emails by script nbSMTP or sendEmail, none of both works, i have tried many things but apeears that the action does not try to execute the script,
    when i run mannually the script it runs ok and send email but by zabbix action if i put on media configuration an invalid script name there is no error on audit/events and says "sent" but the script does not ran.
    my scripts is in /etc/zabbix/alert.d/ folder and in zabbix_server.conf i have the parameter AlertScriptsPath=/etc/zabbix/alert.d/
    tks.
  • 0siris
    • Nov 2010
    • 76
    when you run the script manually, do yo run it as user zabbix?
    • lberaldi
      • Jul 2012
      i have tried, but i will try it again to ensure that, but the file (script) permissions is ok and i tried 777 too but does not run, neither try to run. Even if i put on media an script name that does not exist no errors was logged and said "sent" on audit/event.
      • anjiytwok
        • Dec 2012
        • 44
        Hello 0siris,
        Could you please tell me, the script what i need write.
        I have created the media setting and trigger and events,
        But need only what is the content in the script, then i can configure it in the zabbix_server.conf
        please advise in the script.
