Monitoring -> Overview after upgrade to 2
  • bartonn
    • Feb 2008
    So my upgrade appears to have gone well, however one issue. The View of Overview under Monitoring shows all triggers, as in each trigger for each machine name. Where as it should be condensed by trigger name on one side and machine name on the other.
    Any idea how to fix this?
    Cheers,
    -Barton
  • f.koch
    • Feb 2010
    • 85
    Cheers,
    -Barton
    have you ${HOSTNAME} macro in your triggers? so this resolves with 2.0 all triggers are uniq, if you remove ${HOSTNAME} it works again
    • bartonn
      • Feb 2008
      No, I don't have any macros. Perhaps I am not explaining the situation very well.
      along the top of the Overview page I see each machine name. On the left hand I see something like the following:
      /etc/passwd has been changed on server server1
      /etc/passwd has been changed on server server2
      /etc/passwd has been changed on server server3
      So on and so forth for each trigger.
      Cheers,
      -Barton
      • bartonn
        • Feb 2008
        Ahh HA! yes that did work.
        Under templates triggers I removed all instances of {HOSTNMAE} and everything looks good again.
        Cheers,
        -Barton
