Zabbix monitoring stopped working
  • isaac2k2
    • Aug 2012
    Hi All
    Before now I was seeing update from Zabbix regarding our PMTA queue on a particular graph but for some reason it stopped working
    I have checked the port connection between the zabbix servers and pmta server and I can telnet to the zabbix server on port 10050.
    Is there anything I need to check on the graph configuration? Note: Other graphs where this server is been monitored is working.
  • isaac2k2
    • Aug 2012
    Just noticed that the other graphs where the server are configured are not reporting also. So it must be something between the server and the zabbix server
    • tchjts1
      • May 2008
      • 1605
      Check the zabbix_agentd.log on your monitored host.
      Maybe the agent needs restarted.
      You could also look at the items in Zabbix GUI for that host and out to the right if there is a red X, hover your mouse over it to see the error message.
      If those fail to produce any clues, restarting Zabbix server process might be in order.
      • isaac2k2
        • Aug 2012
        Thanks for the reply. I have fixed the issue .
        • imransafi
          • Aug 2012
          • 24
          Dear isaac2k2!
          I am still facing the problem, I was monitoring windows event logs of my domain controller running on windows server 2008 but after some minutes it stop minoring the logs but whenever I restart the windows server 2008 it starts logs monitoring for some minutes again it stops can you please let me know how to fix it?
          Best Regards,
          Imran Safi
