### Option: HousekeepingFrequency
# How often Zabbix will perform housekeeping procedure (in hours).
# Housekeeping is removing unnecessary information from history, alert, and alarms tables.
# Mandatory: no
# Range: 1-24
# Default:
# HousekeepingFrequency=1
HousekeepingFrequency=4
### Option: MaxHousekeeperDelete
# The table "housekeeper" contains "tasks" for housekeeping procedure in the format:
# [housekeeperid], [tablename], [field], [value].
# No more than 'MaxHousekeeperDelete' rows (corresponding to [tablename], [field], [value])
# will be deleted per one task in one housekeeping cycle.
# SQLite3 does not use this parameter, deletes all corresponding rows without a limit.
# If set to 0 then no limit is used at all. In this case you must know what you are doing!
# Mandatory: no
# Range: 0-1000000
# Default:
# MaxHousekeeperDelete=500
MaxHousekeeperDelete=10000
### Option: DisableHousekeeping
# If set to 1, disables housekeeping.
# Mandatory: no
# Range: 0-1
# Default:
# DisableHousekeeping=0
You will have to restart the zabbix server when you are finished making changes.
