zabbix does not check returncode of media scripts
  • rrr
    • Sep 2007
    • 100
    I have several media scripts which are giving return codes on success or unsuccessful operation. But zabbix does not check the return code of those media scripts. If a media script is executed it will always be marked with "ok" in gui. Is there any possibility that zabbix will check the return code?
  • richlv
    • Oct 2005
    • 3112
    is that with the latest zabbix version ? at least missing scripts should be shown as failures since 2.0.1 (https://support.zabbix.com/browse/ZBXNEXT-1259)
    • rrr
      • Sep 2007
      • 100
      Yes, its with the lastest zabbix version. But the script is not missing - zabbix is just ignoring the returncode which the script is sending.
      • richlv
        • Oct 2005
        • 3112
        that might be a feature request then, although i believe zabbix just runs the command and lets it run, it does not even wait for the execution to complete...
        • rrr
          • Sep 2007
          • 100
          Ok, I've created a feature request: ZBXNEXT-1380
