Items never being removed from the queue 1.8.14
  • jroberson
    • May 2008
    • 124
    I've got about 140+ items in the queue delayed for about 10-15 days and I can't clear them. These are pretty strange because the "next check" is actually in the past (like about 10-15 days ago). I've tried disabling the item and then re-enabling it, and even disabling and re-enabling the host. The only thing that seems to work is to clear the history of that item. I don't really want to do that for 140+ random items. I've got the history set for 30 days on most of those so I'm hoping in about 20-15 days these will just drop out, but if anybody has any other suggestion, I'm open to those as well.
    Thanks!
  • jroberson
    • May 2008
    • 124
    Sorry, forgot to mention that it seems all of these are SNMP checks.
    • jroberson
      • May 2008
      • 124
      Another twist, about 15 days ago (Aug 6th) I upgraded to v1.8.14 from v1.8.12. I wonder if some of those SNMP changes in those versions might have done something un-intended (or possibly "intended").
      • safpsr
        • Aug 2007
        • 70
        I have the same problem with the version 1.8.10.
        Does somebody have the same problem and solve it ?
        • jroberson
          • May 2008
          • 124
          Oddly enough, I think my problem was because by DB volume was full. I'm working on a solution for that now. I'll let you know if that fixes it for me, but I doubt that is your problem.
