Bug with SNMP Zabbix 2.0.2 and source IP
  • Alex_SYB
    • Feb 2012
    • 133
    Hi
    when i set source IP, zabbix is unable to start any SNMP sessions
    I believe this is the section
    #ifdef HAVE_SNMP_SESSION_LOCALNAME
    if (NULL != CONFIG_SOURCE_IP)
    session.localname = CONFIG_SOURCE_IP;
    #endif
    SOCK_STARTUP;
    if (NULL == (ss = snmp_open(&session)))
    SOCK_CLEANUP;
    zbx_snprintf(err, MAX_STRING_LEN, "Cannot open snmp session");
    in zabbix/src/zabbix_server/poller/checks_snmp.c
    everything works well when i don't set the source address.
    reason i need source address is zabbix was on another machine and is now merged into a new machine.
    all the firewall rules and agent configs have been set to the old address !
  • edgecase
    • Sep 2012
    Commenting out the section:
    #endif
    and creating the file /etc/snmp/zabbix_server.conf:
    [snmp] clientaddr 1.2.3.4:40161
    Is working for me, although I do get frequent:
    13610:20120902:173143.687 item [timor:Port_FastEthernet0_20_InUcastPkts] became not supported: Error doing snmp_open()
    I think it is polling the same snmp host with the same fixed source port, so the socket is "busy"? I had to specify the 40161 since default 161 conflicts with snmpd running on zabbix_server host. I think other software using UDP sockets uses a range of port numbers, I'll have to look into that.
    • Alex_SYB
      • Feb 2012
      • 133
      I will have to check this out, my main problem now is i use a precompiled version. have to convince the compiler that there is an issue
      • dimir
        Zabbix developer
        • Apr 2011
        • 1080
        Related issue: ZBX-3379
        • bouba
          • Dec 2012
          I upgraded to 2.0.4 on Debian Squeeze, but I still have the issue. By reading ZBX-3379, I can't figure if it is solved without the "iproute" workaround...
          No more info please ?
          • dimir
            Zabbix developer
            • Apr 2011
            • 1080
            It's solved on the Zabbix side. The bug is resolved, the fix is available in development branch (see the link in comment) until it's closed. When closed - it will appear in "2.0" branch and in 2.0.5 release.
            • bouba
              • Dec 2012
              Hi again,
              Thanks for previous help/infos.
              I'm unable to find when Pre-2.0.5rc1 will become the official 2.0.5 stable. Sorry for that, but I desperately need the SNMP client "SourceIP" patch...any idea about when it will be available ?
              Rgds,
              • dimir
                Zabbix developer
                • Apr 2011
                • 1080
                2.0.5rc1 will be out in 2-3 weeks. I have attached the patch to ZBX-3379 if you would like to have it earlier.
