net.if.total - Graph
  • sorciq
    • Aug 2012
    • 15
    Hi all!
    It's my first post here, so I would like to welcome everyone. ;-)
    But, get to the point. I have problem with traffic calculation. I have no idea, why when I restart my server graph with monitoring traffic reset. Also when interfaces reset count TX and RX it's happen the same. Why?
    Why zabbix doesn't add value all the time and shows up as it should?
    Maybe I have wrong items...
    net.if.in[eth0,bytes], store value as is, numeric(float), Unit B, what else I have to do or change?
    Regards,
    Simon
  • raoul
    • Nov 2011
    • 29
    What do you mean by graph resets ?
    There's no more history data in graph, or last value goes back to 0 ?
    Can you attach a hard copy of your graph ?
    Cheers,
    r/
    • sorciq
      • Aug 2012
      • 15
      Thank you for your replay.
      I mean, when RX or TX bytes on interfaces reset my Graph also reset. I susspect, that normally shoudn't.
      I attached image: http://postimage.org/image/xl1rg0r47/full/
      You can see three "pick" - I think is wrong and Zabbix should cumulate.
      Regards,
      Simon
      • raoul
        • Nov 2011
        • 29
        your interface counters reset happens at 01:50 ?
        Zabbix agent information is gathered from server ; so when you reset counters, Zabbix agent can only send the current values (0 or so at the moment counters have just been reset).
        • sorciq
          • Aug 2012
          • 15
          Ok, It's loggical. But, did Zabbix should not add preveious value to current and continue the graph? Because he always stop before reach 10GB.
          I'm using agent 2.0.2 on server, and latest full distriubtion of zabbix-server (Xen guest).
          Maybe I show you how I create items:
          Incoming traffic: http://postimage.org/image/lta2pbbvv/
          Outgoin traffic looks like as incoming
          Total traffic: http://postimage.org/image/apbwgnhon/
          Is that correct?
          Regards,
          Simon
          • raoul
            • Nov 2011
            • 29
            As long as there's some traffic, you can see your absolute values increasing.
            As soon as you clear counters, they go back to 0 ... as counters value is 0 since this moment ... then increase again.
            The behaviour really seems normal to me.
            Cheers,
            r/
            • sorciq
              • Aug 2012
              • 15
              I cannot understand why Total traffic on graph back to 0. But maybe it's working thats way.
              But, second thing. Why max value of traffic total is all the time 7,59GB? This is should be increasing all the time; in this moment I don't know what traffic is from entire month, because always reset or stop on before reach 10GB.
              Have you look on my items settings? Is that correct?
              Regards,
              Simon
              • raoul
                • Nov 2011
                • 29
                Yes your configuration seems correct.
                Values are stored "as is", which means as gathered from the servers interface counters.
                I don't know why counter always resets before reaching 10GB ... did you manually check on your server ? Are counter displaying values different from the ones you see in Zabbix ?
                • sorciq
                  • Aug 2012
                  • 15
                  Hi again!
                  So, please tell me... how I can check how many data I downloaded or uploaded durng the month if every counter reset on my interfaces zabbix not cumulate the data?
                  For example:
                  I have 4GB outcoming and 4GB incoming. Total traffic is 8GB. My interfaces reset counter (what is normally). Then it start count from the begining, but it should be add new traffic to last one? That is correct?
                  Best regards,
                  Simon
                  • SirMax
                    • Jul 2012
                    • 14
                    The first thing i have thought about was:
                    create a delta item, then create calculate item, which will be sum all deltas.
                    Though Zabbix is not a traffic calculation program, imho.
                    • sorciq
                      • Aug 2012
                      • 15
                      Thank you for your reply.
                      So, for example I have to set "Store value" as Delta (simple change). Key: net.if.in[eth0,bytes]; type of information Numeric. The same for .out and total.
                      ok, but I cannot understand how to create calculate item. ;-( Zabbix required Key, but what type of key I should put? And Formula? last(net.if.in[eth0,bytes]) or sum()?
                      I don't know.
                      Best Regards,
                      Simon
                      • SirMax
                        • Jul 2012
                        • 14
                        Sorry for a long answer.
                        I have made a little trick:
                        create item like this:
                        Type: Calculated
                        key: testsum
                        Formula: last("net.if.out[Intel(R) PRO/1000 MT Network Adapter]") + last("testsum")
                        Looks like this trick is working, but, this counter is not reliable.
                        one of the problems: It don't work untill you have a first value for the key "testsum"
                        Workaround create item with formula with last("net.if.out[Intel(R) PRO/1000 MT Network Adapter]"), then after a couple of minutes change to increment formula.
                        IMHO this is a bad solution....
                        • sire
                          • Jul 2010
                          • 210
                          Yes, this is a bad solution, because last("net.if.out[Intel(R) PRO/1000 MT Network Adapter]") will not count all traffic deltas since the last update of testsum. Better use something like sum("net.if.out[Intel(R) PRO/1000 MT Network Adapter]",60)+last("testsum"). However this will not be accurate too.
                          Regards,
                          Sergey Syreskin
                          Monitored hosts: 2646 / Active items: 23604 / Server performance: 765.74
                          Temporary out of Zabbix business
                          • SirMax
                            • Jul 2012
                            • 14
                            If net.if.out[Intel(R) PRO/1000 MT Network Adapter] update time is 60 second (and our counter update is the same 60 sec too), then we can assume that my expression is correct.
                            I have done this solution as an example of possibility to do smth like traffic counter.
                            But this solution is not accurate, of course
                            • sire
                              • Jul 2010
                              • 210
                              #15
                              I agree with you.
                              Regards,
                              Sergey Syreskin
