Active Client Auto Registration issues
  • guido
    • Sep 2012
    we have problems with Active Client Auto Registration.
    Clients do not show up in Zabbix server.
    Agent conf:
    Server=192.168.10.11
    Hostname=hostname of server
    StartAgents=5
    DebugLevel=3
    LogFile= c:\windows\mon\zabbix_agentd.log
    Timeout=5
    EnableRemoteCommands=1
    Do we miss something in the agent conf?
    Zabbix Server:
    We have setup this:
    http://www.zabbix.com/wiki/howto/config/autoregister
    Zabbix server: 2.0
    hosts: 1 (zabbix server)
    Zabbix agent: latest
  • Jason
    • Nov 2007
    • 431
    Have you configured an auto-discovery action?
    Look in Hosts->Actions and set Event-Source to Auto-registration
    • guido
      • Sep 2012
      Yes i have Jason,
      Auto registration hosts
      Add host
      Add to host groups: TTC Total
      Link to templates: Template OS Windows
      • guido
        • Sep 2012
        Must the agent be a active agent?
        StartAgents=5
        DebugLevel=3
        Timeout=5
        The firewall log accept the clients:
        ACCEPT 192.168.45.10:49339 vlan45 192.168.10.11:10050 LAN-10-ICT tcp ACCESS FORWARD
        ACCEPT 192.168.20.11:57367 LAN-20-TA 192.168.10.11:10050 LAN-10-ICT tcp ACCESS FORWARD
        ACCEPT 192.168.45.10:49327 vlan45 192.168.10.11:10050 LAN-10-ICT tcp ACCESS FORWARD
        • OttoK
          • Jan 2013
          • 9
          I have the same problem. Everything is supposedly configured according to all instructions available but nothing happens and there is no way to debug why.
          • OttoK
            • Jan 2013
            • 9
            I went into the MySQL database on the Zabbix server and noticed there are no autoreg lines in the database. It seems as if there is some issue with the client, maybe it does not even try to auto-register?
            mysql> select * from autoreg_host;
            Empty set (0.04 sec)
            • Starko
              • Aug 2012
              • 93
              StartAgents=5
              DebugLevel=3
              Timeout=5
              The Registration comes from an active client. so you also need:
              ServerActive=192.168.10.11
              • OttoK
                • Jan 2013
                • 9
                We how now been using this very simple conf for over a year:
                StartAgents=0
                ServerActive=zabbix-server.example.com
                Hostname=host.example.com
                Nothing more is needed. StartAgents needs to be 0 to disable non-active agents.
                • aib
                  • Jan 2014
                  • 1615
                  just a little note:
                  Hostname={name_of_your_client_PC}
                  Don't write a name of zabbix server in Hostname= keyword.
                  Sincerely yours,
                  Aleksey
                  • OttoK
                    • Jan 2013
                    • 9
                    Originally posted by aib
                    just a little note:
                    Oh no, now I exposed to the whole world that I am the owner of example.com
