Macros in map labels not working?
  • dennisj
    • Apr 2010
    • 24
    I'm trying to set the label of a host icon on a map to "{HOST.NAME}" in order for the label to display the hostname however all I get is a literal "{HOST.NAME}" string under the icon. Is there a special option that needs to be set to enable this?
    This is even shown in screenshots here so there has to be a way to make it work:
    http://www.zabbix.com/documentation/...ation/maps/map
    Regards,
    Dennis
  • dennisj
    • Apr 2010
    • 24
    Never mind. I just realized that I have to check under Monitoring->Maps to see the fully rendered label or use the "Expand Macros" option.
    • raoul
      • Nov 2011
      • 29
      Try {HOSTNAME} instead of {HOST.NAME}
      Cheers,
      r/
      • hektolitr
        • Oct 2012
        zabbix 2.0 map add goto options
        hi,
        in love with zabbix, but i have one small problem. how can i add options to goto menu on map element like on image.
        its in default config of zabbix server, but i cant figure out howto configure this menu on another map hosts.
        thanks for replies !
        i need host screens on another map elements
