Zabbix server is not running:
  • Moorthy938
    • Mar 2016
    • 9
    #46
    zabbix server is not working properly
    Thanks for your replay bro..
    According to your post
    this command says killall -9 <PID> command not found.
    then how can i finout the correct PID in this i got confused... pls replay mee.
    am waiting for your replay..
    • mahsa
      • Feb 2016
      Actually you have some ways to find zabbix server PID. You can install one command named top then run top and find the zabbix server PID then kill theses processes by run kill -9 <PID>. One another option is find zabbix-server PID by running this command pgrep zabbix . About the screenshot you have uploaded, you'd better check the zabbix-server config file which are located in /etc/zabbix/zabbix_server.conf. Sometimes the last changes you have performed into this file has caused the problem.
