Upgrade from beta9 to beta10
  • bgd
    • May 2006
    • 9
    just performed an update from beta9 to beta10, and I have noticed the following problems:
    - In the Monitoring->Overview screen, I get a lot of rows with '$1' instead of the actual mount point (e.g. "Free number of inodes on $1", "Free disk space on $1", "Used disk space on $1" and so on...)
    - As values for the free space for the disks (on the "Latest data" page), I'm getting the right value, but with the wrong suffix ('MB' instead of 'GB')
    - As values for the total space for the root partition I get '0B' which is obviously wrong. Used disk space is also '0B' for all partitions.
    On the 'Overview' page I also get triggers being showed, triggers that I've disabled for all the clients (e.g. FTP Server is down on all clients, is disabled as trigger for all clients, but it's showed in red in 'Overview'). How can one disable that (so that only the activated triggers are also showed)?
    I am running Novell Linux Desktop on both clients. Could somebody tell me where should I start fixing things?
    Thx,
    bgd
  • erisan500
    • Aug 2005
    • 285
    Look at the items, they have a "Use custom multiplier" set with 0. Remove the custom multiplier or change 0 to 1.
    EriSan
    • Dryam
      • Jun 2006
      I'm use beta12 and also find this bug...
