vfs.fs.size works directly on agent but ZBX_NOTSUPPORTED when requested from server
  • ILIV
    • Oct 2012
    • 28
    I'm trying to learn more about low-level discovery, and luckily I have a problem to tackle
    This is a simple test configuration that I run on a single computer utilizing virtualbox VM instance where I run server, and agent is running directly on my personal laptop.
    Server is running on Debian Squeeze
    root@bitarena:~# dpkg -l |grep zabbix
    ii zabbix-agent 1:2.0.2~cmd1-1 network monitoring solution - agent
    ii zabbix-frontend-php 1:2.0.2~cmd1-1 network monitoring solution - PHP front-end
    rc zabbix-proxy-mysql 1:2.0.2~cmd1-1 network monitoring solution - proxy (using MySQL)
    ii zabbix-server-pgsql 1:2.0.2~cmd1-1 network monitoring solution - server (using PostgreSQL)
    while Agent on Arch Linux
    root@sega /home/iliv % pacman -Q |grep zabbix
    zabbix-agent 2.0.2-1
    Problem
    root@bitarena:~# zabbix_get -s sega -k vfs.fs.size[/,free]
    2815614976
    root@bitarena:~# zabbix_get -s sega -k vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,free]
    ZBX_NOTSUPPORTED
    root@bitarena:~# zabbix_get -s sega -k vfs.fs.discovery
    "data":[
    "{#FSNAME}":"\/",
    "{#FSTYPE}":"rootfs"},
    "{#FSNAME}":"\/proc",
    "{#FSTYPE}":"proc"},
    "{#FSNAME}":"\/sys",
    "{#FSTYPE}":"sysfs"},
    "{#FSNAME}":"\/dev",
    "{#FSTYPE}":"devtmpfs"},
    "{#FSNAME}":"\/run",
    "{#FSTYPE}":"tmpfs"},
    "{#FSNAME}":"\/",
    "{#FSTYPE}":"ext3"},
    "{#FSNAME}":"\/dev\/pts",
    "{#FSTYPE}":"devpts"},
    "{#FSNAME}":"\/dev\/shm",
    "{#FSNAME}":"\/proc\/sys\/fs\/binfmt_misc",
    "{#FSTYPE}":"binfmt_misc"},
    "{#FSNAME}":"\/tmp",
    "{#FSNAME}":"\/home\/iliv\/.gvfs",
    "{#FSTYPE}":"fuse.gvfs-fuse-daemon"},
    "{#FSNAME}":"\/run\/media\/iliv\/9d244934-d9fa-4a8e-8dd7-5c595f5518cf",
    "{#FSTYPE}":"ext2"}]}
    However, it works directly on Agent host:
    iliv@sega ~ % zabbix_agent -t vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,free]
    vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,free] [u|409642881024]
    iliv@sega ~ % zabbix_agent -t vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree]
    vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree] [d|41.606911]
    Screenshots that show automagically LLD-created graphs:
    i.imgur . com / EpRZu . png
    i.imgur . com / EEAKp . png
    Those not supported, of course, don't show up in graphs drop-down list at all.
    I pumped up log debugging output to the max on Zabbix Server/Agent hosts, but it seems to be of little help:
    Server
    root@bitarena:~# tail -f /var/log/zabbix-server/zabbix_server.log |grep iliv
    13721:20121008:081248.519 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/home\/iliv\/.gvfs","{#FSTYPE}":"fuse.gvfs-fuse-daemon"}'
    13721:20121008:081248.522 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/run\/media\/iliv\/9d244934-d9fa-4a8e-8dd7-5c595f5518cf","{#FSTYPE}":"ext2"}'
    13721:20121008:081248.527 End of substitute_discovery_macros() data:'/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf'
    13721:20121008:081248.528 End of substitute_key_macros():SUCCEED data:'vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,free]'
    13721:20121008:081248.529 query [txnlev:1] [select distinct i.itemid from items i,item_discovery id where i.itemid=id.itemid and id.parent_itemid=23391 and i.key_='vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,free]']
    13721:20121008:081248.534 query [txnlev:1] [select itemid from items where hostid=10086 and key_='vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,free]' and itemid<>23435]
    update items set name='Free disk space on $1',key_='vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,free]',type=0,value_type=3,data_type=0,delay=60,delay_f lex='',history=7,trends=365,trapper_hosts='',units ='B',multiplier=0,delta=0,formula='1',logtimefmt=' ',valuemapid=null,params='',ipmi_sensor='',snmp_co mmunity='',snmp_oid='',port='',snmpv3_securityname ='',snmpv3_securitylevel=0,snmpv3_authpassphrase=' ',snmpv3_privpassphrase='',authtype=0,username='', password='',publickey='',privatekey='',description ='',interfaceid=3,flags=4 where itemid=23435;
    13721:20121008:081248.574 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/home\/iliv\/.gvfs","{#FSTYPE}":"fuse.gvfs-fuse-daemon"}'
    13721:20121008:081248.575 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/run\/media\/iliv\/9d244934-d9fa-4a8e-8dd7-5c595f5518cf","{#FSTYPE}":"ext2"}'
    13721:20121008:081248.579 End of substitute_discovery_macros() data:'/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf'
    13721:20121008:081248.579 End of substitute_key_macros():SUCCEED data:'vfs.fs.inode[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree]'
    13721:20121008:081248.581 query [txnlev:1] [select distinct i.itemid from items i,item_discovery id where i.itemid=id.itemid and id.parent_itemid=23392 and i.key_='vfs.fs.inode[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree]']
    13721:20121008:081248.583 query [txnlev:1] [select itemid from items where hostid=10086 and key_='vfs.fs.inode[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree]' and itemid<>23437]
    update items set name='Free inodes on $1 (percentage)',key_='vfs.fs.inode[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree]',type=0,value_type=0,data_type=0,delay=60,delay_f lex='',history=7,trends=365,trapper_hosts='',units ='%',multiplier=0,delta=0,formula='1',logtimefmt=' ',valuemapid=null,params='',ipmi_sensor='',snmp_co mmunity='',snmp_oid='',port='',snmpv3_securityname ='',snmpv3_securitylevel=0,snmpv3_authpassphrase=' ',snmpv3_privpassphrase='',authtype=0,username='', password='',publickey='',privatekey='',description ='',interfaceid=3,flags=4 where itemid=23437;
    13721:20121008:081248.627 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/home\/iliv\/.gvfs","{#FSTYPE}":"fuse.gvfs-fuse-daemon"}'
    13721:20121008:081248.629 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/run\/media\/iliv\/9d244934-d9fa-4a8e-8dd7-5c595f5518cf","{#FSTYPE}":"ext2"}'
    13721:20121008:081248.635 End of substitute_discovery_macros() data:'/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf'
    13721:20121008:081248.636 End of substitute_key_macros():SUCCEED data:'vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,total]'
    13721:20121008:081248.637 query [txnlev:1] [select distinct i.itemid from items i,item_discovery id where i.itemid=id.itemid and id.parent_itemid=23393 and i.key_='vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,total]']
    13721:20121008:081248.645 query [txnlev:1] [select itemid from items where hostid=10086 and key_='vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,total]' and itemid<>23439]
    update items set name='Total disk space on $1',key_='vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,total]',type=0,value_type=3,data_type=0,delay=3600,delay _flex='',history=7,trends=365,trapper_hosts='',uni ts='B',multiplier=0,delta=0,formula='1',logtimefmt ='',valuemapid=null,params='',ipmi_sensor='',snmp_ community='',snmp_oid='',port='',snmpv3_securityna me='',snmpv3_securitylevel=0,snmpv3_authpassphrase ='',snmpv3_privpassphrase='',authtype=0,username=' ',password='',publickey='',privatekey='',descripti on='',interfaceid=3,flags=4 where itemid=23439;
    13721:20121008:081248.690 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/home\/iliv\/.gvfs","{#FSTYPE}":"fuse.gvfs-fuse-daemon"}'
    13721:20121008:081248.691 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/run\/media\/iliv\/9d244934-d9fa-4a8e-8dd7-5c595f5518cf","{#FSTYPE}":"ext2"}'
    13721:20121008:081248.695 End of substitute_discovery_macros() data:'/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf'
    13721:20121008:081248.696 End of substitute_key_macros():SUCCEED data:'vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,used]'
    13721:20121008:081248.696 query [txnlev:1] [select distinct i.itemid from items i,item_discovery id where i.itemid=id.itemid and id.parent_itemid=23394 and i.key_='vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,used]']
    13721:20121008:081248.699 query [txnlev:1] [select itemid from items where hostid=10086 and key_='vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,used]' and itemid<>23441]
    update items set name='Used disk space on $1',key_='vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,used]',type=0,value_type=3,data_type=0,delay=60,delay_f lex='',history=7,trends=365,trapper_hosts='',units ='B',multiplier=0,delta=0,formula='1',logtimefmt=' ',valuemapid=null,params='',ipmi_sensor='',snmp_co mmunity='',snmp_oid='',port='',snmpv3_securityname ='',snmpv3_securitylevel=0,snmpv3_authpassphrase=' ',snmpv3_privpassphrase='',authtype=0,username='', password='',publickey='',privatekey='',description ='',interfaceid=3,flags=4 where itemid=23441;
    13721:20121008:081248.741 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/home\/iliv\/.gvfs","{#FSTYPE}":"fuse.gvfs-fuse-daemon"}'
    13721:20121008:081248.743 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/run\/media\/iliv\/9d244934-d9fa-4a8e-8dd7-5c595f5518cf","{#FSTYPE}":"ext2"}'
    13721:20121008:081248.748 End of substitute_discovery_macros() data:'/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf'
    13721:20121008:081248.749 End of substitute_key_macros():SUCCEED data:'vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree]'
    13721:20121008:081248.749 query [txnlev:1] [select distinct i.itemid from items i,item_discovery id where i.itemid=id.itemid and id.parent_itemid=23395 and i.key_='vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree]']
    13721:20121008:081248.754 query [txnlev:1] [select itemid from items where hostid=10086 and key_='vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree]' and itemid<>23443]
    update items set name='Free disk space on $1 (percentage)',key_='vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree]',type=0,value_type=0,data_type=0,delay=60,delay_f lex='',history=7,trends=365,trapper_hosts='',units ='%',multiplier=0,delta=0,formula='1',logtimefmt=' ',valuemapid=null,params='',ipmi_sensor='',snmp_co mmunity='',snmp_oid='',port='',snmpv3_securityname ='',snmpv3_securitylevel=0,snmpv3_authpassphrase=' ',snmpv3_privpassphrase='',authtype=0,username='', password='',publickey='',privatekey='',description ='',interfaceid=3,flags=4 where itemid=23443;
    13721:20121008:081248.833 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/home\/iliv\/.gvfs","{#FSTYPE}":"fuse.gvfs-fuse-daemon"}'
    13721:20121008:081248.835 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/run\/media\/iliv\/9d244934-d9fa-4a8e-8dd7-5c595f5518cf","{#FSTYPE}":"ext2"}'
    13721:20121008:081248.841 End of substitute_discovery_macros() data:'Free inodes is less than 20% on volume /run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf'
    13721:20121008:081248.849 End of substitute_discovery_macros() data:'/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf'
    13721:20121008:081248.850 End of substitute_key_macros():SUCCEED data:'vfs.fs.inode[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree]'
    13721:20121008:081248.851 End of DBlld_expand_trigger_expression() expr:'{sega:vfs.fs.inode[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree].last(0)}<20'
    13721:20121008:081248.853 query [txnlev:1] [select distinct t.triggerid,t.expression from triggers t,trigger_discovery td where t.triggerid=td.triggerid and td.parent_triggerid=13554 and t.description='Free inodes is less than 20% on volume /run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf']
    13721:20121008:081248.861 End of DBlld_expand_trigger_expression() expr:'{sega:vfs.fs.inode[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree].last(0)}<20'
    13721:20121008:081248.861 query [txnlev:1] [select distinct t.triggerid,t.expression from triggers t,functions f,items i where t.triggerid=f.triggerid and f.itemid=i.itemid and i.hostid=10086 and t.description='Free inodes is less than 20% on volume /run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf' and t.triggerid<>13556]
    update triggers set description='Free inodes is less than 20% on volume /run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf',priority=2,comments='',url='',type=0 ,flags=4 where triggerid=13556;
    13721:20121008:081248.914 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/home\/iliv\/.gvfs","{#FSTYPE}":"fuse.gvfs-fuse-daemon"}'
    13721:20121008:081248.915 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/run\/media\/iliv\/9d244934-d9fa-4a8e-8dd7-5c595f5518cf","{#FSTYPE}":"ext2"}'
    13721:20121008:081248.923 End of substitute_discovery_macros() data:'Free disk space is less than 20% on volume /run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf'
    13721:20121008:081248.930 End of substitute_discovery_macros() data:'/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf'
    13721:20121008:081248.931 End of substitute_key_macros():SUCCEED data:'vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree]'
    13721:20121008:081248.934 End of DBlld_expand_trigger_expression() expr:'{sega:vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree].last(0)}<20'
    13721:20121008:081248.934 query [txnlev:1] [select distinct t.triggerid,t.expression from triggers t,trigger_discovery td where t.triggerid=td.triggerid and td.parent_triggerid=13553 and t.description='Free disk space is less than 20% on volume /run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf']
    13721:20121008:081248.943 End of DBlld_expand_trigger_expression() expr:'{sega:vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,pfree].last(0)}<20'
    13721:20121008:081248.945 query [txnlev:1] [select distinct t.triggerid,t.expression from triggers t,functions f,items i where t.triggerid=f.triggerid and f.itemid=i.itemid and i.hostid=10086 and t.description='Free disk space is less than 20% on volume /run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf' and t.triggerid<>13558]
    update triggers set description='Free disk space is less than 20% on volume /run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf',priority=2,comments='',url='',type=0 ,flags=4 where triggerid=13558;
    13721:20121008:081249.019 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/home\/iliv\/.gvfs","{#FSTYPE}":"fuse.gvfs-fuse-daemon"}'
    13721:20121008:081249.022 In DBlld_check_record() jp_row:'{"{#FSNAME}":"\/run\/media\/iliv\/9d244934-d9fa-4a8e-8dd7-5c595f5518cf","{#FSTYPE}":"ext2"}'
    13721:20121008:081249.028 End of substitute_discovery_macros() data:'Disk space usage /run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf'
    13721:20121008:081249.029 query [txnlev:1] [select distinct g.graphid from graphs g,graph_discovery gd where g.graphid=gd.graphid and gd.parent_graphid=541 and g.name='Disk space usage /run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf']
    13721:20121008:081249.035 query [txnlev:1] [select distinct g.graphid from graphs g,graphs_items gi,items i where g.graphid=gi.graphid and gi.itemid=i.itemid and i.hostid=10086 and g.name='Disk space usage /run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf' and g.graphid<>550]
    13721:20121008:081249.044 End of substitute_discovery_macros() data:'/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf'
    13721:20121008:081249.044 End of substitute_key_macros():SUCCEED data:'vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,free]'
    13721:20121008:081249.044 query [txnlev:1] [select itemid from items where hostid=10086 and key_='vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,free]']
    13721:20121008:081249.049 End of substitute_discovery_macros() data:'/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf'
    13721:20121008:081249.050 End of substitute_key_macros():SUCCEED data:'vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,total]'
    13721:20121008:081249.050 query [txnlev:1] [select itemid from items where hostid=10086 and key_='vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,total]']
    13721:20121008:081249.058 DBget_graphitems() [0] itemid:23435 key:'vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,free]'
    13721:20121008:081249.058 DBget_graphitems() [1] itemid:23439 key:'vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,total]'
    update graphs set name='Disk space usage /run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf',width=600,height=340,yaxismin=0.0000 00,yaxismax=0.000000,show_work_period=0,show_trigg ers=0,graphtype=2,show_legend=1,show_3d=1,percent_ left=0.000000,percent_right=0.000000,ymin_type=0,y max_type=0,ymin_itemid=null,ymax_itemid=null,flags =4 where graphid=550;
    Agent
    19266:20121008:182542.245 Requested [vfs.fs.size[/run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf,free]]
    19266:20121008:182542.245 Sending back [ZBX_NOTSUPPORTED]
    What could be wrong there?
    /run/media/iliv/9d244934-d9fa-4a8e-8dd7-5c595f5518cf is a mount point for an external USB drive with ext2 filesystem, nothing too special about it. Well, you've just seen yourself that I can get item values on Agent host without any problems. However, it is when the Server initiates this check things go wrong. Having seen that zabbix_agent process can actually obtain values for vfs.fs.size I'm a little baffled as to why the error says ZBX_NOTSUPPORTED.
    Any ideas what's going on here or how further I could troubleshoot this problem?
  • ILIV
    • Oct 2012
    • 28
    Answering my own question.
    This is a permissions problem. You see, as I wrote yesterday it is an external USB drive connected to a workstation computer running GNOME 3.x, where external media is automatically mounted by D-BUS/udisksd and mount point is granted access permissions of the user that is currently running GNOME session and attempts to automatically mount a disk drive.
    So, my disk is auto-mounted for system user iliv, and it appears udisksd relies on extended attributes to make sure this user can access the drive (I've overlooked that tiny trailing + symbol for so many times!) and zabbix_agentd runs as zabbix shell user
    iliv@sega ~ % lsh /run/media/
    total 0
    drwxr-xr-x 4 root root 80 Oct 4 10:12 .
    drwxr-xr-x 26 root root 840 Oct 9 08:16 ..
    drwxr-x---+ 3 root root 60 Oct 9 12:06 iliv
    iliv@sega ~ % getfacl /run/media/iliv
    getfacl: Removing leading '/' from absolute path names
    # file: run/media/iliv
    # owner: root
    # group: root
    user::rwx
    user:iliv:r-x
    group::---
    mask::r-x
    other::---
    zabbix being 'other' user of course fails to access this mount point.
    If I manually remount drive as root user, zabbix_agentd can pull out numbers no matter what system user it's run as.
