Issue with Zabbix time
  • orion5566
    • Oct 2012
    Hi
    I have an issue with my Zabbix, he shows me two hours less.
    In my virtual machine my clock is correct and my time zone is correct.
    where can I change zabbix time ? or where is it getting this hour?
    Than you
    Regards.
  • nelsonab
    • Sep 2006
    • 1233
    Time is stored/used in three (sometimes 4 or 5 places). For passive items the timestamp recorded in the database is the time of the server the Zabbix server is running on. For active items the time stamp may come from the client. When viewing graphs and other data in the frontend the time used is that of the client on which the web browser is running. However the timezone setting in the the php config file on the frontend server can impact things as well, however the time on the system running the frontend is not often used.
    Hopefully that helps clear things up.
    RHCE, author of zbxapi
    • orion5566
      • Oct 2012
      Thanks for your reply.
      My zabbix dashboard is where the hour is delaying for two hours.
      The emails are being sent with the correct time.
      I checked again my linux date/hour and it´s properly configured.
      I have a lot of machines on diferents places with the time ok, which are sending information and their logs are showed in the dashboard with wrong hour.
      Where can I found the php file configuration?
      Regards.
      • emmanux
        • Mar 2013
        • 47
        locate php.ini
        locate apache.conf | grep zabbix
        • DaiTengu
          • Feb 2014
          Originally posted by emmanux
          locate php.ini
          It's likely you've installed via RPMs. I had the same issue, and it was driving me insane until I came across emmanux's post here. I remembered that in /etc/httpd/conf.d/ there resides zabbix.conf change php_value date.timezone to your timezone.
          then restart apache.
