I'm trying to setup Zabbix for some hours now. I have installed zabbix 2.0.3 from sources.
CentOS 6.3 (2.6.32-279.11.1.el6.x86_64), Apache/2.2.15, PHP 5.5.3.
I have copied all frontend files in /var/www/html/zabbix and set permissions to 644 for files and 755 for folders, and changed owner to apache:apache.
a phpinfo page works fine.
However when I try to open the zabbix folder from the browser, I get blank page, and in error_log I get:
pear is installed and running:
include path is correct. Everything seems to be set up correctly, therefore I can only think that it comes from the zabbix 2.0.3 php files.
Can anyone help me to sort this out ?
[Tue Oct 23 16:22:25 2012] [error] [client 82.146.198.81] PHP Fatal error: Unknown: Failed opening required '/var/www/html/zabbix/index.php' (include_path='.:/usr/share/pear:/usr/share/php') in Unknown on line 0
PEAR Version: 1.9.4
PHP Version: 5.3.3
Zend Engine Version: 2.3.0
Running on: Linux zabbix.hosting.sissaoui.com 2.6.32-279.11.1.el6.x86_64 #1 SMP Tue Oct 16 15:57:10 UTC 2012 x86_64
PHP Version: 5.3.3
