Expected [+CMGS: ] received [+CME ERROR: invalid input value]: For SMS alerts
  • linuxlover.chaitanya
    • Oct 2012
    Hello all,
    I am new here on Zabbix forums and toZabbix as a whole.
    I have deployed Zabbix on Cent OS 6 64 bit system and on a whole I am really happy with it.
    I have been able to add servers to monitoring and make some few changes and add email alerting and actions. I have not yet tweaked graphs and templates and use the default.
    Now with the issue.
    I have been trying to use GSM modem connected to system using serial port to send SMS alerts. But somehow Zabbix is not able to send the alerts on SMS.
    This is what the error in the audit logs look like. And as there is no CME error code, I have not been able to decipher what went wrong and where and how to correct it. I am not sure what Zabbix is expecting and what it is receiving.
    I have searched Zabbix forums and google for the error but have found nothing. I may be searching something wrong.
    Anyone who has this error before or has any idea where should I start?
    PS: I am able to send SMS using minicom.
    Any help would be highly appreciated.
    Regards
    Chaitanya
  • Prometej
    • Oct 2010
    • 21
    FILE sms.c
    #define>ZBX_AT_ESC<---->"\x1B"
    #define ZBX_AT_CTRL_Z<->"\x1A"
    <------>zbx_sms_scenario scenario[] =
    <------><------>{ZBX_AT_ESC<--->, NULL<><------>, 0},<->/* Send <ESC> */
    <------><------>{"AT+CMEE=2\r"<>, ""/*"OK"*/<-->, 10},<>/* verbose error values */
    <------><------>{"ATE0\r"<----->, "OK"<><------>, 10},<>/* Turn off echo */
    <------><------>{"AT\r"><------>, "OK"<><------>, 10},<>/* Init modem */
    <------><------>{"AT+CMGF=1\r"<>, "OK"<><------>, 10},<>/* Switch to text mode */
    <------><------>{"AT+CMGS=\""<->, NULL<><------>, 0},<->/* Set phone number */
    <------><------>{number><------>, NULL<><------>, 0},<->/* Write phone number */
    <------><------>{"\"\r"><------>, "> "<><------>, 10},<>/* Set phone number */
    <------><------>{message<------>, NULL<><------>, 0},<->/* Write message */
    <------><------>{ZBX_AT_CTRL_Z<>, ""<--><------>, 20},<>/* Send message */
    <------><------>{NULL<-><------>, "+CMGS: "<--->, 30},
    <------><------>{NULL<-><------>, ""<--><------>, 10},
    <------><------>{NULL<-><------>, ""<--><------>, 5},<->/* ^Z */
    <------><------>{NULL<-><------>, NULL<><------>, 0}
    <------>zbx_sms_scenario<------>*step = NULL;
    <------>struct termios<><------>options, old_options;
    <------>int<---><------><------>f, ret = SUCCEED;
    Edit as I have in the code file sms.c.
    Recompile zabbih server and the problem is still with the three-error sending SMS (although sent 3 SMS) should disappear. Good luck to you.
    manual AT command from GSM Modems
