2.0.3: Agents becomming unreachable and never recovering
  • lynggaard
    • Sep 2012
    • 11
    Hi
    I am starting to roll out my first zabbix installation, but I have run into a annoying issue event though I have as few as 5-6 agents.
    The agents can be running fine until suddenly the server decides it is unreachable and and tripping the "no data from agent.ping for 5 minutes" trigger. Once that happens I cannot brung back the host.(even after days) I have tried restarting the agent and disable/enable the host on the server neither of which worked.
    The only recourse is to delete and recreate the hosts.
    Zabbix server: 2.0.3 on RHEL 6 with mysql
    Zabbix server hardware: Dual socket 6-core Xeon, not taxed at all
    New values per second: <10
    Zabbix agents (5x): 2.0.3 on RHEL 5
    Agent checks: only passive. Only using the standard "Template OS Linux" which comes out of the box.
    In the logs I see "<some key> failed- First network error, will try again after 15 seconds" but that is it.
    I have tried enabling the debug log on the server and I see some statements like "Failed to evaluate function in expression agent.ping[{HOST.NAME}].nodata(5m)...." and without debug logging
    Tonight I set the Timeout up to 30 seconds, but not sure if that will fix it
    I have tried googling the subject but all the similar problems I found was with version 1.8.x series and looked quite old.
    How to debug/fix??
  • ThanhBT
    • Jan 2013
    i have same problem with Zabbix 2.0 on CentOS and Agent is Windows 2008. It's running ok but sometime trigger alert "unreachable for 5 minutes", but i try ping form Server to Agent and Agent to Server via ssh and cmd is good. Anyone can help us?
