Item calculation in Network maps
  • kalvis.k
    • May 2012
    Hi!
    I`m monitoring few network switches with SNMP. Discovered items are : SwitchName:ifInOctets[Ethernet Routing Switch - Unit 1 Port 24].
    On network map I`d like to make visual link and sum of "ifIn" and "ifOut" Octets on the link. I can`t find formula/macros, how to calculate it directly on the map, not creating new item. When I try to create new item(calculated) and item value: last("SwitchName:ifInOctets[Ethernet Routing Switch - Unit 1 Port 24]")+last("SwitchName:ifOutOctets[Ethernet Routing Switch - Unit 1 Port 24]")
    traffic load is calculated, but when I insert it in link label - it isn`t.
    Maybe someone can help me to figure it out?
  • mbsit
    • Sep 2012
    • 130
    You have to use calculated item, and on the link indicator put THE KEY of this new item.
    KEY not FORMULA ! should be on link indicator
    Bests,
    Grzegorz
    Wdrożenia Zabbix - Warszawa
    Pozdrawiam
    Grzegorz Grabowski
    ____
    WdroĊĵenia, szkolenia, umowy serwisowe
    Warszawa - Polska
