Hard Coded IP failure
  • saintxseiya
    • Oct 2010
    • 17
    Hi all,
    did someone notice the fault, if you are going to use Zabbix on a domain, there are several hardcoded Links, really annoying.
    i.e.
    you log in to your zabbix by using a domain. www.sex-zabbix.org/zabbix
    then you have to go to your templates site i.e. ther you can switch to site 2 and voila the address changes from the domain to the local IP of the server.
    Same for latest values etc.
    Seems to be a big bug.
    Saint.
  • Colttt
    • Mar 2009
    • 878
    please create a bugreport for this.. its the best solution!!
    hmm i cant test it, i dont have a second site in templates..
    Debian-User
    Sorry for my bad english
    • saintxseiya
      • Oct 2010
      • 17
      @ Shadow
      you can try it with every single menu that has more than one site, like HOSTS, latest values etc.
