I've now experienced a big problem with Zabbix, where I selected to clear the history of all (52 of) the items on a single host, which took so long (I never even let it finish) that Zabbix started to run out of History Cache (which was left at default of 8MB) and missed lots of items that it should've monitored.
I killed the MySQL query after it ran for too long and then I even had to stop our Zabbix
I'm using Zabbix Server 1.8.11 with a MySQL InnoDB schema.
The MySQL query that the Zabbix Server (and not the web frontend) executed that took so long was of the format:
"DELETE FROM history_uint WHERE (itemid IN (<list of item id's here>))"
We've never had any issues of this sort with our HouseKeeper.
Our Zabbix server is processing about 130 items/second and the housekeeper typically delete about 500k records per hour:
"housekeeper deleted: 430453 records from history and trends, 4000 records of deleted items, 0 events, 0 alerts, 0 sessions"
Our MySQL server isn't very fast either, but it handles its day to day job just fine. It has very little RAM (3GB), but it has like 6x 10000rpm drives on a RAID controller with 512MB RAM, so it could very well be the culprit. The InnoDB file is taking up 70GB, but this also includes all the deleted data if I'm not mistaken. We're in the process of upgrading the RAM on that server to say 16GB.
My question is: is there a way to limit/throttle that "Clear history for selected" so that it doesn't lock up our whole monitoring system?
So far my workaround is to full clone to host and then to delete the old one, and then letting the HouseKeeper do the cleanup.
Second question: what does the "MaxHousekeeperDelete" Zabbix Server configuration do? Does it imply that only 500 rows would be deleted by the HouseKeeper and then that delete operation is performed say 1000x in our case, until it deleted all 500k rows!?
If it works like this, can that "Clear history for selected" be done in the same way or is it already like that in v2.0.3?
Remarks and suggestions are welcome.
Thank you in advance!
