Zabbix on Suse Linux 10.0
  • christian-hohmann
    • May 2006
    Hi all,
    I try to install Zabbix for a project work on my university. Because my client, i386, runs Suse Linux 10.0 I tryed to compile zabbix for this system. Unfortunately I can't fix it since hours and hours.
    The problem is that I get neither net-snmp nor ucd-snmp running and so no zabbix running.
    Has anybody ever fixed to compile zabbix on a Suse Linux machine?
    Which distribution/ operating system do you recommend? Have you any hints for me?
    Best regrads,
    Christian Hohmann
  • fmtaylor2
    • May 2006
    • 66
    no-snmp
    zabbix will compile fine without snmp support. Try that and see if you can make it go. work on the snmp stuff later.
    I have compiled zabbix under debian, redhat, and slackware. both with and without snmp support.
    On a ease of use / user friendly scale (where 10 is for the clueless and 1 for the guru) I would personally rate them as follows:
    debian: 6
    Redhat: 5
    slackware: 3
    Please note that most of MY systems are slackware (where MY <> work|kid|wife).
    • globe
      • Apr 2006
      • 40
      you have to reinstall the net-snmp package from project HP, then it works. i currently run it on suse 10 with more than 500 Hosts monitoring.
      greets, Globe
      • krusty
        • Oct 2005
        • 222
        I use SuSE 10.0 too. And i monitor more than 1300 router.
        Use the following link to search for devel source of net-snmp and it should work for you. Please check after installing the zabbix, the php.ini file. I have to change on path. If you have any questions plz report.
        Regards,
        Krusty
        SuSE 10.0 Source
        • xstreur
          • May 2006
          Suse 10 and Net-snmp
          greets, Globe
          What version of net-snmp are you using and what packages did you have install first.
          • christian-hohmann
            • May 2006
            Thanks a lot for all your hints. The problem was that when i wanted to install net-snmp from the sourceforge site, it want to have several different packages like becrypt and others.
            A student advised me to change the OS to debian, there i got zabbix working. I guess that this is not realted to suse linux but to my know-how on linux.
            Again thanks for all your advices
            Christian
