server crashes after startup SIGSEGV with --net-snmp
  • tartan75
    • Nov 2012
    I've been setting up a Zabbix server 2.0.3 on a Beagleboard xM (ARM Processor), running Angstrom. Zabbix Agent runs fine and Server runs fine when configured with:
    ./configure --enable-server --enable-agent --with-mysql --enable-ipv6 --with-libcurl
    but when compiled with --with-net-snmp added the server crashes, with the following server log. having seen the thread http://www.zabbix.com/forum/showthread.php?t=3638 I've also tried with sqlite and have the same issue. Any advice on how to debug this would be much appreciated.
    Regards
    Nathan
    1855:20121126:203309.868 Starting Zabbix Server. Zabbix 2.0.3 (revision 30485).
    1855:20121126:203309.869 ****** Enabled features ******
    1855:20121126:203309.869 SNMP monitoring: YES
    1855:20121126:203309.869 IPMI monitoring: NO
    1855:20121126:203309.869 WEB monitoring: YES
    1855:20121126:203309.869 Jabber notifications: NO
    1855:20121126:203309.869 Ez Texting notifications: YES
    1855:20121126:203309.869 ODBC: NO
    1855:20121126:203309.869 SSH2 support: NO
    1855:20121126:203309.869 IPv6 support: YES
    1855:20121126:203309.869 ******************************
    1857:20121126:203309.895 server #1 started [configuration syncer #1]
    1858:20121126:203309.897 server #2 started [db watchdog #1]
    1867:20121126:203309.927 server #9 started [trapper #1]
    1869:20121126:203309.943 server #11 started [trapper #3]
    1870:20121126:203309.944 server #12 started [trapper #4]
    1872:20121126:203309.971 server #14 started [icmp pinger #1]
    1868:20121126:203309.965 server #10 started [trapper #2]
    1871:20121126:203309.968 server #13 started [trapper #5]
    1873:20121126:203309.974 server #15 started [alerter #1]
    1874:20121126:203309.988 server #16 started [housekeeper #1]
    1874:20121126:203310.002 executing housekeeper
    1875:20121126:203309.994 server #17 started [timer #1]
    1883:20121126:203310.018 server #18 started [http poller #1]
    1885:20121126:203310.028 server #20 started [history syncer #1]
    1890:20121126:203310.045 server #21 started [history syncer #2]
    1855:20121126:203310.077 server #0 started [main process]
    1892:20121126:203310.084 server #22 started [history syncer #3]
    1896:20121126:203310.110 server #26 started [self-monitoring #1]
    1895:20121126:203310.111 server #25 started [proxy poller #1]
    1894:20121126:203310.094 server #24 started [escalator #1]
    1893:20121126:203310.093 server #23 started [history syncer #4]
    1874:20121126:203310.843 housekeeper deleted: 0 records from history and trends, 0 records of deleted items, 0 events, 0 alerts, 0 sessions
    1864:20121126:203313.715 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x10]. Crashing ...
    1860:20121126:203313.721 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x10]. Crashing ...
    1860:20121126:203313.722 ====== Fatal information: ======
    1860:20121126:203313.722 program counter not available for this architecture
    1860:20121126:203313.722 === Registers: ===
    1860:20121126:203313.722 register dump not available for this architecture
    1860:20121126:203313.722 === Backtrace: ===
    1860:20121126:203313.722 0: zabbix_server(print_fatal_info+0x54) [0x48e60]
    1860:20121126:203313.723 === Memory map: ===
    1863:20121126:203313.729 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x10]. Crashing ...
    1863:20121126:203313.730 ====== Fatal information: ======
    1863:20121126:203313.730 program counter not available for this architecture
    1863:20121126:203313.730 === Registers: ===
    1863:20121126:203313.730 register dump not available for this architecture
    1863:20121126:203313.730 === Backtrace: ===
    1863:20121126:203313.730 0: zabbix_server(print_fatal_info+0x54) [0x48e60]
    1863:20121126:203313.730 === Memory map: ===
    1859:20121126:203313.735 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x10]. Crashing ...
    1859:20121126:203313.735 ====== Fatal information: ======
    1859:20121126:203313.736 program counter not available for this architecture
    1859:20121126:203313.736 === Registers: ===
    1859:20121126:203313.736 register dump not available for this architecture
    1859:20121126:203313.736 === Backtrace: ===
    1859:20121126:203313.736 0: zabbix_server(print_fatal_info+0x54) [0x48e60]
    1859:20121126:203313.736 === Memory map: ===
    1859:20121126:203313.737 00008000-000d1000 r-xp 00000000 b3:02 11259 /usr/local/sbin/zabbix_server
    1859:20121126:203313.737 000d8000-000da000 rw-p 000c8000 b3:02 11259 /usr/local/sbin/zabbix_server
    1859:20121126:203313.737 000da000-00169000 rw-p 00000000 00:00 0 [heap]
    1859:20121126:203313.737 40000000-4001d000 r-xp 00000000 b3:02 87855 /lib/ld-2.9.so
    1859:20121126:203313.737 4001d000-40024000 rw-p 00000000 00:00 0
    1859:20121126:203313.737 40024000-40025000 r--p 0001c000 b3:02 87855 /lib/ld-2.9.so
    1859:20121126:203313.738 40025000-40026000 rw-p 0001d000 b3:02 87855 /lib/ld-2.9.so
    1859:20121126:203313.738 40026000-40064000 r-xp 00000000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1859:20121126:203313.738 40064000-4006c000 ---p 0003e000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1859:20121126:203313.738 4006c000-40096000 rw-p 0003e000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1859:20121126:203313.738 40096000-400d8000 r-xp 00000000 b3:02 156958 /usr/lib/libcurl.so.4.2.0
    1859:20121126:203313.738 400d8000-400df000 ---p 00042000 b3:02 156958 /usr/lib/libcurl.so.4.2.0
    1859:20121126:203313.738 400df000-400e1000 rw-p 00041000 b3:02 156958 /usr/lib/libcurl.so.4.2.0
    1859:20121126:203313.738 400e1000-40143000 r-xp 00000000 b3:02 156314 /usr/lib/libgcrypt.so.11.4.4
    1862:20121126:203313.744 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x10]. Crashing ...
    1862:20121126:203313.744 ====== Fatal information: ======
    1862:20121126:203313.744 program counter not available for this architecture
    1862:20121126:203313.744 === Registers: ===
    1862:20121126:203313.744 register dump not available for this architecture
    1862:20121126:203313.744 === Backtrace: ===
    1862:20121126:203313.745 0: zabbix_server(print_fatal_info+0x54) [0x48e60]
    1862:20121126:203313.745 === Memory map: ===
    1862:20121126:203313.745 00008000-000d1000 r-xp 00000000 b3:02 11259 /usr/local/sbin/zabbix_server
    1862:20121126:203313.745 000d8000-000da000 rw-p 000c8000 b3:02 11259 /usr/local/sbin/zabbix_server
    1862:20121126:203313.746 000da000-00169000 rw-p 00000000 00:00 0 [heap]
    1862:20121126:203313.746 40000000-4001d000 r-xp 00000000 b3:02 87855 /lib/ld-2.9.so
    1862:20121126:203313.746 4001d000-40024000 rw-p 00000000 00:00 0
    1862:20121126:203313.746 40024000-40025000 r--p 0001c000 b3:02 87855 /lib/ld-2.9.so
    1862:20121126:203313.746 40025000-40026000 rw-p 0001d000 b3:02 87855 /lib/ld-2.9.so
    1862:20121126:203313.746 40026000-40064000 r-xp 00000000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1861:20121126:203313.749 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x10]. Crashing ...
    1861:20121126:203313.750 ====== Fatal information: ======
    1861:20121126:203313.750 program counter not available for this architecture
    1861:20121126:203313.750 === Registers: ===
    1861:20121126:203313.750 register dump not available for this architecture
    1861:20121126:203313.750 === Backtrace: ===
    1861:20121126:203313.750 0: zabbix_server(print_fatal_info+0x54) [0x48e60]
    1861:20121126:203313.751 === Memory map: ===
    1861:20121126:203313.751 00008000-000d1000 r-xp 00000000 b3:02 11259 /usr/local/sbin/zabbix_server
    1861:20121126:203313.751 000d8000-000da000 rw-p 000c8000 b3:02 11259 /usr/local/sbin/zabbix_server
    1861:20121126:203313.751 000da000-00169000 rw-p 00000000 00:00 0 [heap]
    1861:20121126:203313.751 40000000-4001d000 r-xp 00000000 b3:02 87855 /lib/ld-2.9.so
    1861:20121126:203313.752 4001d000-40024000 rw-p 00000000 00:00 0
    1861:20121126:203313.752 40024000-40025000 r--p 0001c000 b3:02 87855 /lib/ld-2.9.so
    1861:20121126:203313.752 40025000-40026000 rw-p 0001d000 b3:02 87855 /lib/ld-2.9.so
    1861:20121126:203313.752 40026000-40064000 r-xp 00000000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1861:20121126:203313.752 40064000-4006c000 ---p 0003e000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1861:20121126:203313.752 4006c000-40096000 rw-p 0003e000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1861:20121126:203313.752 40096000-400d8000 r-xp 00000000 b3:02 156958 /usr/lib/libcurl.so.4.2.0
    1861:20121126:203313.752 400d8000-400df000 ---p 00042000 b3:02 156958 /usr/lib/libcurl.so.4.2.0
    1861:20121126:203313.752 400df000-400e1000 rw-p 00041000 b3:02 156958 /usr/lib/libcurl.so.4.2.0
    1861:20121126:203313.752 400e1000-40143000 r-xp 00000000 b3:02 156314 /usr/lib/libgcrypt.so.11.4.4
    1861:20121126:203313.753 40143000-4014b000 ---p 00062000 b3:02 156314 /usr/lib/libgcrypt.so.11.4.4
    1861:20121126:203313.753 4014b000-4014d000 rw-p 00062000 b3:02 156314 /usr/lib/libgcrypt.so.11.4.4
    1861:20121126:203313.753 4014d000-40153000 r-xp 00000000 b3:02 87835 /lib/librt-2.9.so
    1861:20121126:203313.753 40153000-4015a000 ---p 00006000 b3:02 87835 /lib/librt-2.9.so
    1861:20121126:203313.753 4015a000-4015b000 r--p 00005000 b3:02 87835 /lib/librt-2.9.so
    1861:20121126:203313.753 4015b000-4015c000 rw-p 00006000 b3:02 87835 /lib/librt-2.9.so
    1861:20121126:203313.753 4015c000-4016d000 r-xp 00000000 b3:02 156272 /usr/lib/libz.so.1.2.3
    1861:20121126:203313.753 4016d000-40174000 ---p 00011000 b3:02 156272 /usr/lib/libz.so.1.2.3
    1861:20121126:203313.754 40174000-40175000 rw-p 00010000 b3:02 156272 /usr/lib/libz.so.1.2.3
    1861:20121126:203313.754 40175000-40210000 r-xp 00000000 b3:02 156313 /usr/lib/libgnutls.so.26.16.13
    1861:20121126:203313.754 40210000-40218000 ---p 0009b000 b3:02 156313 /usr/lib/libgnutls.so.26.16.13
    1861:20121126:203313.754 40218000-4021c000 rw-p 0009b000 b3:02 156313 /usr/lib/libgnutls.so.26.16.13
    1861:20121126:203313.754 4021c000-4029e000 r-xp 00000000 b3:02 157508 /usr/lib/libnetsnmp.so.20.0.0
    1861:20121126:203313.754 4029e000-402a6000 ---p 00082000 b3:02 157508 /usr/lib/libnetsnmp.so.20.0.0
    1884:20121126:203313.761 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x10]. Crashing ...
    1884:20121126:203313.761 ====== Fatal information: ======
    1884:20121126:203313.761 program counter not available for this architecture
    1884:20121126:203313.761 === Registers: ===
    1884:20121126:203313.761 register dump not available for this architecture
    1884:20121126:203313.761 === Backtrace: ===
    1884:20121126:203313.762 0: zabbix_server(print_fatal_info+0x54) [0x48e60]
    1884:20121126:203313.762 === Memory map: ===
    1864:20121126:203313.715 ====== Fatal information: ======
    1864:20121126:203313.762 program counter not available for this architecture
    1864:20121126:203313.762 === Registers: ===
    1864:20121126:203313.762 register dump not available for this architecture
    1864:20121126:203313.763 === Backtrace: ===
    1864:20121126:203313.763 0: zabbix_server(print_fatal_info+0x54) [0x48e60]
    1864:20121126:203313.763 === Memory map: ===
    1864:20121126:203313.763 00008000-000d1000 r-xp 00000000 b3:02 11259 /usr/local/sbin/zabbix_server
    1864:20121126:203313.764 000d8000-000da000 rw-p 000c8000 b3:02 11259 /usr/local/sbin/zabbix_server
    1864:20121126:203313.764 000da000-00169000 rw-p 00000000 00:00 0 [heap]
    1864:20121126:203313.764 40000000-4001d000 r-xp 00000000 b3:02 87855 /lib/ld-2.9.so
    1864:20121126:203313.764 4001d000-40024000 rw-p 00000000 00:00 0
    1864:20121126:203313.764 40024000-40025000 r--p 0001c000 b3:02 87855 /lib/ld-2.9.so
    1864:20121126:203313.764 40025000-40026000 rw-p 0001d000 b3:02 87855 /lib/ld-2.9.so
    1864:20121126:203313.764 40026000-40064000 r-xp 00000000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1864:20121126:203313.764 40064000-4006c000 ---p 0003e000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1864:20121126:203313.764 4006c000-40096000 rw-p 0003e000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1864:20121126:203313.764 40096000-400d8000 r-xp 00000000 b3:02 156958 /usr/lib/libcurl.so.4.2.0
    1864:20121126:203313.765 400d8000-400df000 ---p 00042000 b3:02 156958 /usr/lib/libcurl.so.4.2.0
    1864:20121126:203313.765 400df000-400e1000 rw-p 00041000 b3:02 156958 /usr/lib/libcurl.so.4.2.0
    1864:20121126:203313.765 400e1000-40143000 r-xp 00000000 b3:02 156314 /usr/lib/libgcrypt.so.11.4.4
    1864:20121126:203313.765 40143000-4014b000 ---p 00062000 b3:02 156314 /usr/lib/libgcrypt.so.11.4.4
    1864:20121126:203313.765 4014b000-4014d000 rw-p 00062000 b3:02 156314 /usr/lib/libgcrypt.so.11.4.4
    1864:20121126:203313.765 4014d000-40153000 r-xp 00000000 b3:02 87835 /lib/librt-2.9.so
    1864:20121126:203313.765 40153000-4015a000 ---p 00006000 b3:02 87835 /lib/librt-2.9.so
    1864:20121126:203313.765 4015a000-4015b000 r--p 00005000 b3:02 87835 /lib/librt-2.9.so
    1864:20121126:203313.766 4015b000-4015c000 rw-p 00006000 b3:02 87835 /lib/librt-2.9.so
    1864:20121126:203313.766 4015c000-4016d000 r-xp 00000000 b3:02 156272 /usr/lib/libz.so.1.2.3
    1864:20121126:203313.766 4016d000-40174000 ---p 00011000 b3:02 156272 /usr/lib/libz.so.1.2.3
    1864:20121126:203313.766 40174000-40175000 rw-p 00010000 b3:02 156272 /usr/lib/libz.so.1.2.3
    1864:20121126:203313.766 40175000-40210000 r-xp 00000000 b3:02 156313 /usr/lib/libgnutls.so.26.16.13
    1864:20121126:203313.766 40210000-40218000 ---p 0009b000 b3:02 156313 /usr/lib/libgnutls.so.26.16.13
    1864:20121126:203313.766 40218000-4021c000 rw-p 0009b000 b3:02 156313 /usr/lib/libgnutls.so.26.16.13
    1864:20121126:203313.766 4021c000-4029e000 r-xp 00000000 b3:02 157508 /usr/lib/libnetsnmp.so.20.0.0
    1864:20121126:203313.766 4029e000-402a6000 ---p 00082000 b3:02 157508 /usr/lib/libnetsnmp.so.20.0.0
    1864:20121126:203313.767 402a6000-402a8000 rw-p 00082000 b3:02 157508 /usr/lib/libnetsnmp.so.20.0.0
    1864:20121126:203313.767 402a8000-402c7000 rw-p 00000000 00:00 0
    1864:20121126:203313.767 402c7000-40401000 r-xp 00000000 b3:02 156414 /usr/lib/libcrypto.so.1.0.0
    1864:20121126:203313.767 40401000-40409000 ---p 0013a000 b3:02 156414 /usr/lib/libcrypto.so.1.0.0
    1864:20121126:203313.767 40409000-4041b000 rw-p 0013a000 b3:02 156414 /usr/lib/libcrypto.so.1.0.0
    1864:20121126:203313.767 4041b000-4041e000 rw-p 00000000 00:00 0
    1864:20121126:203313.767 4041e000-40488000 r-xp 00000000 b3:02 87834 /lib/libm-2.9.so
    1864:20121126:203313.767 40488000-4048f000 ---p 0006a000 b3:02 87834 /lib/libm-2.9.so
    1864:20121126:203313.767 4048f000-40490000 r--p 00069000 b3:02 87834 /lib/libm-2.9.so
    1864:20121126:203313.767 40490000-40491000 rw-p 0006a000 b3:02 87834 /lib/libm-2.9.so
    1864:20121126:203313.768 40491000-404a1000 r-xp 00000000 b3:02 87840 /lib/libresolv-2.9.so
    1864:20121126:203313.768 404a1000-404a8000 ---p 00010000 b3:02 87840 /lib/libresolv-2.9.so
    1864:20121126:203313.768 404a8000-404a9000 r--p 0000f000 b3:02 87840 /lib/libresolv-2.9.so
    1864:20121126:203313.768 404a9000-404aa000 rw-p 00010000 b3:02 87840 /lib/libresolv-2.9.so
    1864:20121126:203313.768 404aa000-404ac000 rw-p 00000000 00:00 0
    1864:20121126:203313.768 404ac000-404b6000 r-xp 00000000 b3:02 87858 /lib/libgcc_s.so.1
    1864:20121126:203313.768 404b6000-404bd000 ---p 0000a000 b3:02 87858 /lib/libgcc_s.so.1
    1864:20121126:203313.768 404bd000-404be000 rw-p 00009000 b3:02 87858 /lib/libgcc_s.so.1
    1864:20121126:203313.769 404be000-405d7000 r-xp 00000000 b3:02 87830 /lib/libc-2.9.so
    1864:20121126:203313.769 405d7000-405df000 ---p 00119000 b3:02 87830 /lib/libc-2.9.so
    1864:20121126:203313.769 405df000-405e1000 r--p 00119000 b3:02 87830 /lib/libc-2.9.so
    1864:20121126:203313.769 405e1000-405e2000 rw-p 0011b000 b3:02 87830 /lib/libc-2.9.so
    1864:20121126:203313.769 405e2000-405e5000 rw-p 00000000 00:00 0
    1864:20121126:203313.769 405e5000-405ee000 r-xp 00000000 b3:02 87826 /lib/libcrypt-2.9.so
    1864:20121126:203313.769 405ee000-405f5000 ---p 00009000 b3:02 87826 /lib/libcrypt-2.9.so
    1864:20121126:203313.769 405f5000-405f6000 r--p 00008000 b3:02 87826 /lib/libcrypt-2.9.so
    1864:20121126:203313.769 405f6000-405f7000 rw-p 00009000 b3:02 87826 /lib/libcrypt-2.9.so
    1864:20121126:203313.769 405f7000-4061e000 rw-p 00000000 00:00 0
    1864:20121126:203313.770 4061e000-40630000 r-xp 00000000 b3:02 87839 /lib/libnsl-2.9.so
    1864:20121126:203313.770 40630000-40637000 ---p 00012000 b3:02 87839 /lib/libnsl-2.9.so
    1860:20121126:203313.770 00008000-000d1000 r-xp 00000000 b3:02 11259 /usr/local/sbin/zabbix_server
    1860:20121126:203313.770 000d8000-000da000 rw-p 000c8000 b3:02 11259 /usr/local/sbin/zabbix_server
    1860:20121126:203313.770 000da000-00169000 rw-p 00000000 00:00 0 [heap]
    1860:20121126:203313.770 40000000-4001d000 r-xp 00000000 b3:02 87855 /lib/ld-2.9.so
    1860:20121126:203313.770 4001d000-40024000 rw-p 00000000 00:00 0
    1860:20121126:203313.771 40024000-40025000 r--p 0001c000 b3:02 87855 /lib/ld-2.9.so
    1860:20121126:203313.771 40025000-40026000 rw-p 0001d000 b3:02 87855 /lib/ld-2.9.so
    1860:20121126:203313.771 40026000-40064000 r-xp 00000000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1860:20121126:203313.771 40064000-4006c000 ---p 0003e000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1860:20121126:203313.771 4006c000-40096000 rw-p 0003e000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1860:20121126:203313.771 40096000-400d8000 r-xp 00000000 b3:02 156958 /usr/lib/libcurl.so.4.2.0
    1860:20121126:203313.771 400d8000-400df000 ---p 00042000 b3:02 156958 /usr/lib/libcurl.so.4.2.0
    1860:20121126:203313.771 400df000-400e1000 rw-p 00041000 b3:02 156958 /usr/lib/libcurl.so.4.2.0
    1860:20121126:203313.771 400e1000-40143000 r-xp 00000000 b3:02 156314 /usr/lib/libgcrypt.so.11.4.4
    1860:20121126:203313.772 40143000-4014b000 ---p 00062000 b3:02 156314 /usr/lib/libgcrypt.so.11.4.4
    1860:20121126:203313.772 4014b000-4014d000 rw-p 00062000 b3:02 156314 /usr/lib/libgcrypt.so.11.4.4
    1860:20121126:203313.772 4014d000-40153000 r-xp 00000000 b3:02 87835 /lib/librt-2.9.so
    1860:20121126:203313.772 40153000-4015a000 ---p 00006000 b3:02 87835 /lib/librt-2.9.so
    1860:20121126:203313.772 4015a000-4015b000 r--p 00005000 b3:02 87835 /lib/librt-2.9.so
    1860:20121126:203313.772 4015b000-4015c000 rw-p 00006000 b3:02 87835 /lib/librt-2.9.so
    1860:20121126:203313.772 4015c000-4016d000 r-xp 00000000 b3:02 156272 /usr/lib/libz.so.1.2.3
    1860:20121126:203313.772 4016d000-40174000 ---p 00011000 b3:02 156272 /usr/lib/libz.so.1.2.3
    1860:20121126:203313.772 40174000-40175000 rw-p 00010000 b3:02 156272 /usr/lib/libz.so.1.2.3
    1860:20121126:203313.773 40175000-40210000 r-xp 00000000 b3:02 156313 /usr/lib/libgnutls.so.26.16.13
    1860:20121126:203313.773 40210000-40218000 ---p 0009b000 b3:02 156313 /usr/lib/libgnutls.so.26.16.13
    1860:20121126:203313.773 40218000-4021c000 rw-p 0009b000 b3:02 156313 /usr/lib/libgnutls.so.26.16.13
    1860:20121126:203313.773 4021c000-4029e000 r-xp 00000000 b3:02 157508 /usr/lib/libnetsnmp.so.20.0.0
    1860:20121126:203313.773 4029e000-402a6000 ---p 00082000 b3:02 157508 /usr/lib/libnetsnmp.so.20.0.0
    1860:20121126:203313.773 402a6000-402a8000 rw-p 00082000 b3:02 157508 /usr/lib/libnetsnmp.so.20.0.0
    1860:20121126:203313.773 402a8000-402c7000 rw-p 00000000 00:00 0
    1860:20121126:203313.773 402c7000-40401000 r-xp 00000000 b3:02 156414 /usr/lib/libcrypto.so.1.0.0
    1860:20121126:203313.774 40401000-40409000 ---p 0013a000 b3:02 156414 /usr/lib/libcrypto.so.1.0.0
    1860:20121126:203313.774 40409000-4041b000 rw-p 0013a000 b3:02 156414 /usr/lib/libcrypto.so.1.0.0
    1860:20121126:203313.774 4041b000-4041e000 rw-p 00000000 00:00 0
    1860:20121126:203313.774 4041e000-40488000 r-xp 00000000 b3:02 87834 /lib/libm-2.9.so
    1860:20121126:203313.774 40488000-4048f000 ---p 0006a000 b3:02 87834 /lib/libm-2.9.so
    1860:20121126:203313.774 4048f000-40490000 r--p 00069000 b3:02 87834 /lib/libm-2.9.so
    1860:20121126:203313.774 40490000-40491000 rw-p 0006a000 b3:02 87834 /lib/libm-2.9.so
    1860:20121126:203313.774 40491000-404a1000 r-xp 00000000 b3:02 87840 /lib/libresolv-2.9.so
    1860:20121126:203313.774 404a1000-404a8000 ---p 00010000 b3:02 87840 /lib/libresolv-2.9.so
    1860:20121126:203313.774 404a8000-404a9000 r--p 0000f000 b3:02 87840 /lib/libresolv-2.9.so
    1860:20121126:203313.775 404a9000-404aa000 rw-p 00010000 b3:02 87840 /lib/libresolv-2.9.so
    1860:20121126:203313.775 404aa000-404ac000 rw-p 00000000 00:00 0
    1860:20121126:203313.775 404ac000-404b6000 r-xp 00000000 b3:02 87858 /lib/libgcc_s.so.1
    1860:20121126:203313.775 404b6000-404bd000 ---p 0000a000 b3:02 87858 /lib/libgcc_s.so.1
    1860:20121126:203313.775 404bd000-404be000 rw-p 00009000 b3:02 87858 /lib/libgcc_s.so.1
    1860:20121126:203313.775 404be000-405d7000 r-xp 00000000 b3:02 87830 /lib/libc-2.9.so
    1860:20121126:203313.775 405d7000-405df000 ---p 00119000 b3:02 87830 /lib/libc-2.9.so
    1860:20121126:203313.775 405df000-405e1000 r--p 00119000 b3:02 87830 /lib/libc-2.9.so
    1860:20121126:203313.775 405e1000-405e2000 rw-p 0011b000 b3:02 87830 /lib/libc-2.9.so
    1860:20121126:203313.776 405e2000-405e5000 rw-p 00000000 00:00 0
    1860:20121126:203313.776 405e5000-405ee000 r-xp 00000000 b3:02 87826 /lib/libcrypt-2.9.so
    1860:20121126:203313.776 405ee000-405f5000 ---p 00009000 b3:02 87826 /lib/libcrypt-2.9.so
    1860:20121126:203313.776 405f5000-405f6000 r--p 00008000 b3:02 87826 /lib/libcrypt-2.9.so
    1860:20121126:203313.776 405f6000-405f7000 rw-p 00009000 b3:02 87826 /lib/libcrypt-2.9.so
    1860:20121126:203313.776 405f7000-4061e000 rw-p 00000000 00:00 0
    1860:20121126:203313.776 4061e000-40630000 r-xp 00000000 b3:02 87839 /lib/libnsl-2.9.so
    1860:20121126:203313.776 40630000-40637000 ---p 00012000 b3:02 87839 /lib/libnsl-2.9.so
    1860:20121126:203313.776 40637000-40638000 r--p 00011000 b3:02 87839 /lib/libnsl-2.9.so
    1860:20121126:203313.777 40638000-40639000 rw-p 00012000 b3:02 87839 /lib/libnsl-2.9.so
    1860:20121126:203313.777 40639000-4063b000 rw-p 00000000 00:00 0
    1860:20121126:203313.777 4063b000-4063e000 r-xp 00000000 b3:02 156316 /usr/lib/libgpg-error.so.0.3.0
    1860:20121126:203313.777 4063e000-40645000 ---p 00003000 b3:02 156316 /usr/lib/libgpg-error.so.0.3.0
    1860:20121126:203313.777 40645000-40646000 rw-p 00002000 b3:02 156316 /usr/lib/libgpg-error.so.0.3.0
    1860:20121126:203313.777 40646000-4065a000 r-xp 00000000 b3:02 87842 /lib/libpthread-2.9.so
    1860:20121126:203313.777 4065a000-40661000 ---p 00014000 b3:02 87842 /lib/libpthread-2.9.so
    1860:20121126:203313.777 40661000-40662000 r--p 00013000 b3:02 87842 /lib/libpthread-2.9.so
    1860:20121126:203313.777 40662000-40663000 rw-p 00014000 b3:02 87842 /lib/libpthread-2.9.so
    1862:20121126:203313.746 40064000-4006c000 ---p 0003e000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1863:20121126:203313.779 00008000-000d1000 r-xp 00000000 b3:02 11259 /usr/local/sbin/zabbix_server
    1863:20121126:203313.779 000d8000-000da000 rw-p 000c8000 b3:02 11259 /usr/local/sbin/zabbix_server
    1863:20121126:203313.779 000da000-00169000 rw-p 00000000 00:00 0 [heap]
    1863:20121126:203313.779 40000000-4001d000 r-xp 00000000 b3:02 87855 /lib/ld-2.9.so
    1863:20121126:203313.779 4001d000-40024000 rw-p 00000000 00:00 0
    1863:20121126:203313.779 40024000-40025000 r--p 0001c000 b3:02 87855 /lib/ld-2.9.so
    1863:20121126:203313.779 40025000-40026000 rw-p 0001d000 b3:02 87855 /lib/ld-2.9.so
    1863:20121126:203313.780 40026000-40064000 r-xp 00000000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1863:20121126:203313.780 40064000-4006c000 ---p 0003e000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1863:20121126:203313.780 4006c000-40096000 rw-p 0003e000 b3:02 156986 /usr/lib/libmysqlclient.so.16.0.0
    1863:20121126:203313.780 40096000-400d8000 r-xp 00000000 b3:02 156958 /usr/lib/libcurl.so.4.2.0
    1863:20121126:203313.780 400d8000-400df000 ---p 00042000 b3:02 156958 /usr/lib/libcurl.so.4.2.0
    1863:20121126:203313.780 400df000-400e1000 rw-p 00041000 b3:02 156958 /usr/lib/libcurl.so.4.2.0
    1863:20121126:203313.780 400e1000-40143000 r-xp 00000000 b3:02 156314 /usr/lib/libgcrypt.so.11.4.4
    1863:20121126:203313.780 40143000-4014b000 ---p 00062000 b3:02 156314 /usr/lib/libgcrypt.so.11.4.4
    1863:20121126:203313.780 4014b000-4014d000 rw-p 00062000 b3:02 156314 /usr/lib/libgcrypt.so.11.4.4
    1863:20121126:203313.781 4014d000-40153000 r-xp 00000000 b3:02 87835 /lib/librt-2.9.so
    1863:20121126:203313.781 40153000-4015a000 ---p 00006000 b3:02 87835 /lib/librt-2.9.so
    1863:20121126:203313.781 4015a000-4015b000 r--p 00005000 b3:02 87835 /lib/librt-2.9.so
    1863:20121126:203313.781 4015b000-4015c000 rw-p 00006000 b3:02 87835 /lib/librt-2.9.so
    1863:20121126:203313.781 4015c000-4016d000 r-xp 00000000 b3:02 156272 /usr/lib/libz.so.1.2.3
    1863:20121126:203313.781 4016d000-40174000 ---p 00011000 b3:02 156272 /usr/lib/libz.so.1.2.3
    1863:20121126:203313.781 40174000-40175000 rw-p 00010000 b3:02 156272 /usr/lib/libz.so.1.2.3
    1863:20121126:203313.781 40175000-40210000 r-xp 00000000 b3:02 156313 /usr/lib/libgnutls.so.26.16.13
    1863:20121126:203313.781 40210000-40218000 ---p 0009b000 b3:02 156313 /usr/lib/libgnutls.so.26.16.13
    1863:20121126:203313.782 40218000-4021c000 rw-p 0009b000 b3:02 156313 /usr/lib/libgnutls.so.26.16.13
    1863:20121126:203313.782 4021c000-4029e000 r-xp 00000000 b3:02 157508 /usr/lib/libnetsnmp.so.20.0.0
    1863:20121126:203313.782 4029e000-402a6000 ---p 00082000 b3:02 157508 /usr/lib/libnetsnmp.so.20.0.0
    1863:20121126:203313.782 402a6000-402a8000 rw-p 00082000 b3:02 157508 /usr/lib/libnetsnmp.so.20.0.0
    1863:20121126:203313.782 402a8000-402c7000 rw-p 00000000 00:00 0
    1863:20121126:203313.782 402c7000-40401000 r-xp 00000000 b3:02 156414 /usr/lib/libcrypto.so.1.0.0
    1863:20121126:203313.782 40401000-40409000 ---p 0013a000 b3:02 156414 /usr/lib/libcrypto.so.1.0.0
    1863:20121126:203313.782 40409000-4041b000 rw-p 0013a000 b3:02 156414 /usr/lib/libcrypto.so.1.0.0
    1864:20121126:203313.822 ================================
    1855:20121126:203313.824 One child process died (PID:1864,exitcode/signal:255). Exiting ...
    1855:20121126:203315.827 syncing history data...
    1855:20121126:203315.827 syncing history data done
    1855:20121126:203315.827 syncing trends data...
    1855:20121126:203315.828 syncing trends data done
    1855:20121126:203315.829 Zabbix Server stopped. Zabbix 2.0.3 (revision 30485).
