Were experiencing some weird problem with zabbix agent en custom user parameters. We have been running custom parameters for a while with out any problems but recently it stopped working.
We had the following custom parameter:
But now it returns ZBX_NOTSUPPORTED for some reason:
I first thought that there was something wrong with the script or that user permission where wrong but when i run the script as the user zabbix it executes without any problems
Next i thought that there was something wrong with my zabbix configuration. So i did a brand new install in a virtual machine and i activated one of the example user parameters "system.test"
I restarted the zabbix agent and to my surprise this one also failed...
This leaves me with no clue what is wrong or how to fix it. Even with the debug level at 4 there is no indicator what is going wrong. I am testing this on a clean ubuntu 10.04 installation with zabbix-agent version 1.8.1
Does anybody have an idea whats wrong or how to debug any further ?
UserParameter=linux_updates,/usr/lib/update-notifier/apt-check --human-readable|grep "security update"|cut -d " " -f1
# zabbix_agent -t linux_updates linux_updates [m|ZBX_NOTSUPPORTED]
# sudo -u zabbix /usr/lib/update-notifier/apt-check --human-readable|grep "security update"|cut -d " " -f1 0
UserParameter=system.test,who|wc -l
# zabbix_agentd -t system.test system.test [m|ZBX_NOTSUPPORTED]
ii zabbix-agent 1:1.8.1-1ubuntu1 network monitoring solution - agent zabbix_agentd --version ZABBIX Agent (daemon) v1.8.1 (revision 9702) (27 January 2010) Compilation time: Apr 6 2010 01:54:49
