I manage servers which are spread into platforms. Each platform is monitored by a zabbix-proxy.
Last week-end, one of our proxy went down and I therefore got alerts for every single server monitored by the proxy, instead of only the proxy's alert.
I figured out that I forgot to put dependency against the proxy.
But That said, I also did not find any way to automatically get the dependency setted up.
First point: since some servers are monitored by a proxy and some are not (typically zabbix SQL servers), I just can't set up dependency inside the template or I'll have to have one template per service per proxy.
Second point: as far as I know, there are no macro available which represent the proxy monitoring the host and even if there is, I don't know how to implement following rule:
"For a given trigger, if the host is monitored by a proxy then trigger depends on proxy availability; if the host is not monitored by a proxy, then there are no dependency against proxy."
So: is there any way to implement it into zabbix core ? I think this could be a nice feature to minimize setup cost
Regards,
JB
Regards,
JB
