Mikoomi MongoDB plugin not working.
  • jdehnert
    • Jun 2011
    • 10
    I'm running into an issue with my Zabbix server and the latest Mikoomi MongoDB scripts.
    I'm running Zabbix 2.0.4 on Centos 6.3, installed via yum, and I have install the Mikoomi MongoDB plugin from http://code.google.com/p/mikoomi/.
    The basic Linux OS templates are working fine. My files are in /etc/zabbix/externalscripts/ and the permissions are set so that they are owned and executable by zabbix.
    If I run the shell script by hand...
    ./mikoomi-mongodb-plugin.sh -D -h dev-web-1 -p 27017 -z dev-web-1
    it returns "0" and creates 2 files in /tmp. The data one seems to have data, but the log file has the following message...
    mikoomi-mongodb-plugin.php:Successfully connected to mongoDB using connect string 10.183.37.168:27017
    sh: zabbix_sender: command not found
    I'm using the shell script that came with the the php file. I could switch to the simplified version posted at http://pastie.org/4194044, but I'm not sure that this shell scripts is causing the problem.
    There also seemed to be 2 macros that were already set. Here is what the macros section looks like now...
    So $HOSTNAME and $PORT were already there when I went to install the other 3 macros.
    One other item that might be causing me grief. When I went to import the template, it threw out an error about Memory already existing in a template. I edited the XML file an changed "Memory" to "MongoDB Memory" and the resolved the conflict and allowed me to import the template. I don't think this could be causing a problem as it was just an Application Name holding 5 trappers that are different from the apps in the system default templates, but it merits mentioning in case I'm really wrong about that.
  • jdehnert
    • Jun 2011
    • 10
    No one has used this software or has a clue?
    Oh well. Back to the drawing board.
