Failed to connect to database: Error: Lost connection to MySQL server during query
  • just2blue4u
    • Apr 2006
    • 347
    Hi!
    For the 2nd time, Zabbix server (beta9) simply stops working.
    Here is the last part of the server.log:
    012374:20060530:224619 Failed to connect to database: Error: Lost connection to
    012368:20060530:224619 One server process died. Shutting down...
    012368:20060530:224619 ZABBIX server is down.
    I was able to restart zabbix server again without problems.
    The MySQL database (MyISAM) is @ localhost and works fine (no entry in mysqld.log).
    As a workaround, i think i'll create a cronjop to restart zabbix.
    Please, can anybody tell me why the server stops and what i can do against it?
    Big ZABBIX is watching you!
    (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
  • krusty
    • Oct 2005
    • 222
    I have located the same problem a few times ago.
    I made one crontjob which will restarted the zabbix_server process
    • just2blue4u
      • Apr 2006
      • 347
      This is my cron entry (still testing):
      */5 * * * * test "$(pidof zabbix_server)" || (echo 'ZABBIX Server ist nicht aktiv, versuche neu zu starten...'; /etc/init.d/zabbix_server start && echo 'ZABBIX Server wurde neu gestartet!' || echo 'FEHLER: NEUSTART FEHLGESCHLAGEN!!!')
      Nevertheless, i'm still searching a clean way to PREVENT the stopping of the server...
