Itens "Not Supported" on Zabbix
  • Ninux
    • Dec 2012
    Hi
    Why the zabbix received the status "OK" at a moment and in other received "Not Supported" for the same item?
    Im using zabbix server 1.8.6 and on host zabbix agent 1.8.2.
  • jalexandre
    • Jul 2010
    • 15
    Ninux,
    Are you certain these values are always 'not null' and always with correct type (string, char, int, float)
    If you are using script, you are doing error treatment?
    Example:
    If you are expecting numeric values, and you script send ' ' (null value) or ' file not found ' (string), your will have a not supported value.
    Sorry bad english.
    [ ] 's
    • heaje
      • Sep 2009
      • 325
      also, does the check always return a value within the timeout period specified in your server config? if it doesn't, that could cause your item unsupported status that you see.
