Zabbix frontend error after upgrading to 2.0.4
  • stammer
    • Dec 2012
    • 18
    Hello everyone
    After I upgrade to version 2.0.4 zabbix, I get an error message when I try to connect to the database (Oracle).
    The message is: Fatal error: Call to undefined function zbx_dbstr () in / etc / httpd / htdocs / zabbix / include / db.inc.php on line 126
    I also upgraded the apache and php. Apache upgraded to version 2.4.3 and php to version 5.4.10.
    When installing the zabbix identifies all requirements to be OK.
    Does anyone know the solution to this problem?
  • blazergst
    • Nov 2007
    • 10
    Knowing nothing about Oracle DB....
    Sounds like it's not connecting to the database. I would run through the setup again and copy the output file zabbix.conf.php it creates into your frontend folder.
    Also ensure you loaded the included database files into your Oracle database. You can find them in the unpacked tar location zabbix-2.0.4/database/oracle/
    (this is skipped in the instructions found here: https://www.zabbix.com/documentation...lation/install )
    • stammer
      • Dec 2012
      • 18
      Great!
      I already resolved the problem...
      Thanks for your help!
      • hand3z
        • Jan 2013
        I'm having a similar issue for a first time installation of 2.0.4. All the requirements on the setup page pass with OK. When I test my Oracle database connection I get the same error:
        Fatal error: Call to undefined function zbx_dbstr() in /deploy/monitor/zabbix-2.0.4/frontends/php/include/db.inc.php on line 126
        Can you tell me what you did to resolve this?
        • ma.castaneda
          • Feb 2013
          The problem is in the select that zabbix does in the test connection to Oracle DB, if you go to line 126 on db.inc.php and change the select for this select it works ok.
          Original: DBexecute('ALTER SESSION SET NLS_NUMERIC_CHARACTERS='.zbx_dbstr('. '));
          Replace by: DBexecute('ALTER SESSION SET NLS_NUMERIC_CHARACTERS=",."');
          Regards,
          Miguel.
