SuseFirewall2 (noobie quesstion)
  • DamNet
    • Jan 2013
    Hi all,
    I'm trying to run openSuse prepeared Zabbix appliance.
    I make all by steps located here https://www.zabbix.com/documentation...nual/appliance
    But at step 4 i got a problem:
    4 Firewall
    By default, only two ports are open - 22 (SSH) and 80 (HTTP). To open additional ports - for example, Zabbix server and agent ports - modify iptables rules with SuSEfirewall2 utility:
    SuSEfirewall2 open EXT TCP zabbix-trapper zabbix-agent
    Then reload the firewall rules:
    SuSEfirewall2 stop
    SuSEfirewall2 start
    when i type SuSEfirewall2 open EXT TCP zabbix-trapper zabbix-agent
    i have got an error:
    -bash: susefirewall2: command not found
    In additional question: i changed network configuration from dhcp to static and cannot cpnnect to servers with SSH (but ping is OK)
    Thanks a lot in advance
  • mcdougak
    • Oct 2013
    • 26
    Same issue
    I'm having the same issue, were you able to find the correct procedure? I'm not finding much online. I'm using the .iso appliance for initial testing and trying to do a simple discovery setup and can't get any results.
    Thanks!
    • f.koch
      • Feb 2010
      • 85
      try running
      /sbin/SuSEfirewall2
      regards
      • mcdougak
        • Oct 2013
        • 26
        Found it
        Thanks for the reply.
        I actually had to elevate to 'su' to execute the original code correctly. I'm not a Linux guy so I think some of these things are just normal for people to try, I'm getting there!
        Thanks again everyone,
        KM
