Gigatec Zabbix Notifier Chrome plugin
  • Michael0
    • Jan 2013
    • 70
    Does anybody got this Zabbix notifier chrome plugin from gigatec already worked?
    The Chromix plugin from the 3rd Party downloads is working fine with:
    hostname/zabbix
    username
    password
    If´I use the same credentials for the gigatec notifier I got nothing displayed.
    I´m using Zabbix server 2.0.4 and Google Chrome version 23xxxx
    regards
  • adenilson
    • Dec 2012
    I tried to make this work and after a few attempts a gave up.
    There is no support even from de developer.
    • Michael0
      • Jan 2013
      • 70
      I have also tried the "Chromix" Plugin, this Plugin is working without any problems.
      But the way how the notifications are working didn´t help me...
      In this plugin you can turn on/off desktop notifications but it isn´t working on my system...
      • Michael0
        • Jan 2013
        • 70
        Just FYI...
        Gigatec just released a new version of the Zabbix Chrome Notifier, now the plugin is working
        • adenilson
          • Dec 2012
          Thank you very much, I've just tested and its working great.
          • Michael0
            • Jan 2013
            • 70
            Does the notifier still work for you?
            Since I´ve upgraded from 2.0.4 to 2.0.6 new alerts will popup at the notifier as before, but when a problem is solved its not automatically removed from the notifier tool bar popup.
            Until I open the notifier, go to settings and click on save (I think its forcing a refresh), then the notifier is up to date.
            • adenilson
              • Dec 2012
              I'm running through the same problem, but my zabbix is still 2.0.4.
              Maybe it has something to do with chrome and the plugin version. I reinstalled it at no avail.
              • Michael0
                • Jan 2013
                • 70
                ok, then it is not related to the zabbix upgrade.
                Must be related to any chrome update?
                I´m currently using Chome Version 28.0.1500.72
                • adenilson
                  • Dec 2012
                  Maybe... I was just wondering.
                  I got some different news now, after my post I could see that notifications are indeed refreshed, but I have a slight impression about the update interval not working properly.
                  I'll run some tests now.
                  • adenilson
                    • Dec 2012
                    Bad news.
                    I set the update interval to 10 secs and still no refresh after 10 minutes.
                    Yes, we have a problem. =/
                    • Michael0
                      • Jan 2013
                      • 70
                      I´ve already contacted the gigatec support team, lets wait for their answer in this case
                      • gigatec
                        • Sep 2011
                        • 15
                        Hi there,
                        we have already fixed this problem. We will release the new version this week. Stay tuned
                        Best regards,
                        Stefan
                        • gigatec
                          • Sep 2011
                          • 15
                          Hi there,
                          we have just released the new version
                          Best regards
                          Stefan
                          • Michael0
                            • Jan 2013
                            • 70
                            Great, thank you!
                            • sfvolf
                              • Oct 2014
                              • 9
                              #15
                              Originally posted by gigatec
                              Hi there,
                              Best regards
                              Stefan
                              http://www.gigatec.de/
                              Hi, Stephen!
                              I have a problem - Zabbix Notifier Chrome plugin does not work with Zabbix 2.4
                              I only see the green ball in the upper right corner, but it does not show me any problems in my network ....
