Simple Check ssh doesn't work
  • boneyard
    • Jan 2013
    I have an item configured with simple check for ssh with this key: net.tcp.service[ssh,,22], but it stays down. i tried with net.tcp.service[tcp,,22], but no positive effect either.
    i can reach a http(s) port on the same target system with a similar key fine, just ssh doesnt work.
    ssh works on the target system, i can login on it.
    anyone that came across this before? what could this be?
    i saw something about a whole setup for an ssh check, so no simple check, that isn't needed for the simple check right?
  • heaje
    • Sep 2009
    • 325
    When you say the check doesn't work, what do you mean? Do you mean that it detects the service as down, or does the item get marked as unsupported?
    • boneyard
      • Jan 2013
      it is marked down (0), it is supported.
      using version 2.0 btw.
      • boneyard
        • Jan 2013
        ok, problem solved, there was some internal routing / firewall issue causing this. at least i know a lot more about zabbix monitoring now.
