hello,
today i've installed zabbix beta12 because i wanted to check new feature - defining system.run as item. everything is cool but when i try to define longer command to execute by agent it's in fact stored in the database. Then when i want to change the command it's cut. i've changed the size of key_ field in items table to 255 chars but it doesn't seem to fix the problem...
could you please check what's wrong ?
