Zabbix 2.0.4 against OpenLDAP Don't load Users
  • gpostiglioni
    • Aug 2012
    • 10
    Hi all, sorry about my english!!
    i'm set zabbix 2.0.4 to authenticate against an OpenLDAP base, the integration seems to work with the configuration below:
    Default authentication => LDAP
    LDAP host =========> 192.168.100.5
    Port ==============> 389
    Base DN ==========> ou=gestao,dc=site2,dc=intranet
    Search attribute ======> uid
    Bind DN ===========> uid=zabbixadm,ou=gestao,dc=site2,dc=intranet
    Bind Password ======> Senha do zabbixadm
    Login =============> zabbixadm
    User password ======> Senha do zabbixadm
    ...so when i click in the "test" button zabbix returns me that the connection is working, so i click in "save" and the authentication is changed to OpenLDAP, but if i try to login into zabbix with any LDAP user it simply doesn't work, its like the user doesn't exist, but if i create an user in zabbix with the same name of an user in LDAP, i can login with that user, so i want to know if this behaviour is normal or not, if not how can i fix it??
  • ahowell
    • Jan 2011
    • 66
    Yes, LDAP is just for authentication. You still have to create users in zabbix.
    • gpostiglioni
      • Aug 2012
      • 10
      Hum thanks,
      so what about groups? there is any group support, so i dont need to always create an user.
      • heaje
        • Sep 2009
        • 325
        I'm not aware of any LDAP group support although it would be great functionality to have. All that the current Zabbix LDAP authentcation implementation gives us is the ability to use LDAP for the password for the user.
        • heaje
          • Sep 2009
          • 325
          One thing that could be done to work around the basic LDAP authentication is to create a custom script that periodically queries LDAP for the list of users that should have access to Zabbix. It could then use the Zabbix API to create/delete users as needed.
