zabbix proxy and eventlog
  • 753713
    • Apr 2006
    • 137
    Hi all,
    I have a very strange problem with zabbix proxy 2.0.4 and windows agent 2.0.4.
    Zabbix Server has the Version 2.0.4 too.
    Windows zabbix agent active send all my eventlogs to the zabbix server throug proxy. After restart the zabbix agent transfers the agent ALL eventlogs again to the server. When the agent connect directly to zabbix server work the monitoring fine.
    See log files ("lastlogsize":0,).
    Any ideas for my problem??
    log with zabbix proxy:
    7436:20130123:141010.779 Starting Zabbix Agent [123456]. Zabbix 2.0.4 (revision 31980).
    7436:20130123:141010.782 In init_collector_data()
    7436:20130123:141010.783 End of init_collector_data()
    7436:20130123:141010.783 In init_perf_collector()
    7436:20130123:141010.783 End of init_perf_collector()
    16204:20130123:141010.784 agent #0 started [collector]
    14164:20130123:141010.785 agent #1 started[listener]
    9908:20130123:141010.785 agent #2 started[listener]
    17868:20130123:141010.786 agent #3 started[listener]
    12700:20130123:141010.786 agent #4 started [active checks]
    16204:20130123:141010.786 In init_cpu_collector()
    12700:20130123:141010.787 In init_active_metrics()
    16204:20130123:141010.787 In get_counter_name() pdhIndex:238
    12700:20130123:141010.788 Buffer: first allocation for 100 elements
    12700:20130123:141010.788 In send_buffer() host:'10.202.142.33' port:10051 values:0/100
    12700:20130123:141010.789 End of send_buffer():SUCCEED
    12700:20130123:141010.789 refresh_active_checks('10.202.142.33',10051)
    12700:20130123:141010.790 Sending [{
    "request":"active checks",
    "host":"123456"}]
    12700:20130123:141010.791 Before read
    12700:20130123:141010.793 Got [{
    "response":"success",
    "data":[
    "key":"eventlog[Application]",
    "delay":60,
    "lastlogsize":0,
    "mtime":0},
    "key":"eventlog[Directory Service]",
    "delay":60,
    "lastlogsize":0,
    "mtime":0},
    "key":"eventlog[DNS Server]",
    "delay":60,
    "lastlogsize":0,
    "mtime":0},
    "key":"eventlog[File Replication Service]",
    "delay":60,
    "lastlogsize":0,
    "mtime":0},
    "key":"eventlog[Setup]",
    "delay":60,
    "lastlogsize":0,
    "mtime":0},
    "key":"eventlog[System]",
    "delay":60,
    "lastlogsize":0,
    "mtime":0}]}]
    agent log without proxy, connect direct to zabbix server:
    :20130123:143837.883 Starting Zabbix Agent [123456]. Zabbix 2.0.4 (revision 31980).
    17044:20130123:143837.883 In init_collector_data()
    17044:20130123:143837.883 End of init_collector_data()
    17044:20130123:143837.898 In init_perf_collector()
    17044:20130123:143837.898 End of init_perf_collector()
    14320:20130123:143837.898 agent #0 started [collector]
    9864:20130123:143837.898 agent #1 started[listener]
    15016:20130123:143837.898 agent #2 started[listener]
    18232:20130123:143837.898 agent #3 started[listener]
    14808:20130123:143837.898 agent #4 started [active checks]
    14320:20130123:143837.898 In init_cpu_collector()
    14808:20130123:143837.898 In init_active_metrics()
    14320:20130123:143837.898 In get_counter_name() pdhIndex:238
    14808:20130123:143837.898 Buffer: first allocation for 100 elements
    14808:20130123:143837.898 In send_buffer() host:'10.190.20.175' port:10051 values:0/100
    14808:20130123:143837.898 End of send_buffer():SUCCEED
    14808:20130123:143837.898 refresh_active_checks('10.190.20.175',10051)
    14808:20130123:143837.930 Sending [{
    "host":"123456"}]
    14808:20130123:143837.930 Before read
    14320:20130123:143838.492 End of get_counter_name():SUCCEED
    14320:20130123:143838.492 In get_counter_name() pdhIndex:6
    14320:20130123:143838.492 In add_perf_counter() counter:'\Prozessor(_Total)\Prozessorzeit (%)' interval:900
    14320:20130123:143838.492 add_perf_counter(): PerfCounter '\Prozessor(_Total)\Prozessorzeit (%)' successfully added
    14320:20130123:143838.492 In add_perf_counter() counter:'\Prozessor(0)\Prozessorzeit (%)' interval:900
    14320:20130123:143838.492 add_perf_counter(): PerfCounter '\Prozessor(0)\Prozessorzeit (%)' successfully added
    14320:20130123:143838.492 In add_perf_counter() counter:'\Prozessor(1)\Prozessorzeit (%)' interval:900
    14320:20130123:143838.492 add_perf_counter(): PerfCounter '\Prozessor(1)\Prozessorzeit (%)' successfully added
    14320:20130123:143838.492 In add_perf_counter() counter:'\Prozessor(2)\Prozessorzeit (%)' interval:900
    14320:20130123:143838.492 add_perf_counter(): PerfCounter '\Prozessor(2)\Prozessorzeit (%)' successfully added
    14320:20130123:143838.492 In add_perf_counter() counter:'\Prozessor(3)\Prozessorzeit (%)' interval:900
    14320:20130123:143838.492 add_perf_counter(): PerfCounter '\Prozessor(3)\Prozessorzeit (%)' successfully added
    14320:20130123:143838.492 In get_counter_name() pdhIndex:2
    14320:20130123:143838.492 In get_counter_name() pdhIndex:44
    14320:20130123:143838.492 In add_perf_counter() counter:'\System\Prozessor-Warteschlangenlänge' interval:900
    14320:20130123:143838.492 add_perf_counter(): PerfCounter '\System\Prozessor-Warteschlangenlänge' successfully added
    14320:20130123:143838.492 End of init_cpu_collector():SUCCEED
    14320:20130123:143838.492 In collect_perfstat()
    14320:20130123:143839.492 In collect_perfstat()
    14808:20130123:143839.742 Got [{
    "data":[
    "delay":60,
    "lastlogsize":1831121,
    "mtime":0},
    "delay":60,
    "lastlogsize":6339,
    "mtime":0},
    "delay":60,
    "lastlogsize":182,
    "mtime":0},
    "delay":60,
    "lastlogsize":107,
    "mtime":0},
    "delay":60,
    "lastlogsize":408965,
    "mtime":0}]}]
    14808:20130123:143839.742 In parse_list_of_checks()
    14808:20130123:143839.742 In disable_all_metrics()
    ______________________________
    Version : 2.0.x
    Server OS: Ubuntu 12.04
    Zabbix Servers: 12
    Monitored Windows Server: ~ 1000
  • zalex_ua
    • Oct 2009
    • 1286
    heh, it is here https://support.zabbix.com/browse/ZBX-3662
