Trying to build Zabbix server from source on Centos 5.8, and during ./configure I get the error:
configure: error: PostgreSQL library not found
My configure command:
The path to pg_config is valid:
Is it looking for libpq?
I've installed the Postgres client/devel/libs rpms on the Zabbix host (64-bit versions). Does Zabbix require 32-bit libs?
Background:
1) I have PostgreSQL 9.2 server (64-bit) on a separate host from the one where Zabbix server is.
2) I've installed the Postgres 64-bit client/devel/lib rpms on the Zabbix server machine:
3) I've added a conf file to /etc/ld.so.conf.d for the Postgres libs, and I've run ldconfig to refresh the shared library cache:
4) I also tried export LD_LIBRARY_PATH=/usr/pgsql-9.2/lib:$LD_LIBRARY_PATH, and that didn't help.
Any thoughts on now to resolve this will be greatly appreciated.
[zabbix@localhost zabbix-2.0.4]$ ./configure --enable-server --with-postgresql=/usr/pgsql/9.2/bin/pg_config -with-net-snmp --with-ssh2 --with-libcurl
[root@localhost tmp]# /usr/pgsql-9.2/bin/pg_config --version PostgreSQL 9.2.2
Background:
[root@localhost zabbix-2.0.4]# yum list postgres* ... [B]Installed Packages postgresql-libs.i386 8.1.23-6.el5_8 installed postgresql-libs.x86_64 8.1.23-6.el5_8 installed postgresql92.x86_64 9.2.2-1PGDG.rhel5 installed postgresql92-devel.x86_64 9.2.2-1PGDG.rhel5 installed postgresql92-libs.x86_64 9.2.2-1PGDG.rhel5 installed[/B] Available Packages postgresql92-contrib.x86_64 9.2.2-1PGDG.rhel5 pgdg92 postgresql92-debuginfo.x86_64 9.2.2-1PGDG.rhel5 pgdg92 postgresql92-docs.x86_64 9.2.2-1PGDG.rhel5 pgdg92 postgresql92-jdbc.x86_64 9.2.1002-1PGDG.rhel5 pgdg92 postgresql92-jdbc-debuginfo.x86_64 9.2.1002-1PGDG.rhel5 pgdg92 postgresql92-odbc.x86_64 09.01.0200-1PGDG.rhel5 pgdg92 postgresql92-odbc-debuginfo.x86_64 09.01.0200-1PGDG.rhel5 pgdg92 postgresql92-plperl.x86_64 9.2.2-1PGDG.rhel5 pgdg92 postgresql92-plpython.x86_64 9.2.2-1PGDG.rhel5 pgdg92 postgresql92-pltcl.x86_64 9.2.2-1PGDG.rhel5 pgdg92 postgresql92-server.x86_64 9.2.2-1PGDG.rhel5 pgdg92 postgresql92-test.x86_64 9.2.2-1PGDG.rhel5 pgdg92
[root@localhost ld.so.conf.d]# ll
total 32
-rw-r--r-- 1 root root 20 Jan 24 17:42 postgresql9.2.conf
-rw-r--r-- 1 root root 276 Nov 1 09:45 vmware-tools-libraries.conf
-rw-r--r-- 1 root root 21 Oct 26 18:07 xulrunner-32.conf
-rw-r--r-- 1 root root 23 Oct 26 18:06 xulrunner-64.conf
[root@localhost ld.so.conf.d]# cat postgresql9.2.conf
/usr/pgsql-9.2/lib/
[root@localhost ld.so.conf.d]# ldconfig -v | grep libpq
libpq.so.5 -> libpq.so.5.5
libpqwalreceiver.so -> libpqwalreceiver.so
libpq.so.4 -> libpq.so.4.1
